Wheels for a 69 Dart
Old Nov 15, 2008 | 01:14 PM
fpereira23's Avatar
Junior Member
Hi,
I'm new to Mopars and I'm not sure what's the lug spacing that I should look for for my 69 Dart. I want to change the stock wheels and I'm not sure if I want to go aftermarket or maybe get some late model wheels and use those instead. Does anybody knows which late model wheels will fit my Dart?
TKS
Old Nov 15, 2008 | 02:00 PM
Crazy4Carz.Com's Avatar
You need to be careful. Your '69 may have the 4 inch bolt circle. These are hard to find wheels, good luck. I changed my rear to an 8.75 and that gave me 4 1/2 out back but I still have the 4 inch up front.
Old Nov 16, 2008 | 07:29 AM
fpereira23's Avatar
Junior Member
TKS,
How do I measure the spacing? I want to be sure.
If It turns out to be a 4, from where can I get the rear end and front end to make it a 4.5? What donor car shouls I look for?
Old Nov 16, 2008 | 07:42 AM
ef8340's Avatar
Senior Member
hi fp
to measure the bolt circle the bolt directly across from the other will give you the measurement either 5 on 4 or 5 on 4 and a half any 73 and a-body will give you a 4.5 bolt circle [ 73 disc brake car 4.5 drum would be 4.] as for rear end a 8.75 a-body rear end will work you'll just have to get aftermarket axles with a 4.5 b.c or you could find a 73 and up 8.25 a-body rear end
goodluck
Terry
ThomasNieman710
Jun 7, 2013 04:47 AM
Vaprea
Apr 13, 2011 02:42 PM
mytracy
Apr 5, 2011 03:56 AM
Dustoff440
Jan 10, 2011 04:55 AM
reilly
May 27, 2009 06:29 PM
