argh another prob on the dart
Old Oct 27, 2008 | 04:55 PM
ef8340's Avatar
Senior Member
well finally got it to take off normal under normal acceleration but cant keep it quiet it seems that it wants to leak from the exhaust manifolds [340 ones] around the 318 heads it likes to blow the gaskets out on the bottoms as there is only maybe less than a 8th of a inch to try and seal it i think im gonna get the ceramic flowtech headers and put them on has ne1 tried these headers before on a a-body? if so how dow they fit????well????? or do i need to just get the regular ones so i cant wack them if needed? as for the 340 exhaust manifolds i'll be wanting to sell these along with those T/A 340 heads i have if ne1 is interested or trade for some other things i need
Old Oct 29, 2008 | 06:49 PM
challenger's Avatar
hey ef i have not had the opportunity to use them headers but if you get the Percy's Seal-4-Good header gaskets you should never have to buy another set of gaskets again , i have had them on my 440 for about 5 years and had them on and off again and again and they conform with what ever headers you put on time and time again ,,, they are reusable which is a big plus for me but just thought they would be cheaper then other headers
Old Oct 30, 2008 | 02:07 AM
you can alwys double the gasket up.
Old Nov 16, 2008 | 07:50 AM
ef8340's Avatar
Senior Member
i found a gasket that works!!!! incase nebody else has 340 exhaust manifolds going onto a 318 i compared a set of 95 dodge ram 318 magnum ones to my old ones they were smaller in diameter and was just the trick i needed but still going to change it over to headers this spring
Old Nov 16, 2008 | 05:52 PM
Crazy4Carz.Com's Avatar
If you want to go headers, TTi the only way to go. THEY FIT! For gaskets, try SCE Copper gaskets. Good luck.
Craig Kozak
13
Mar 6, 2012 08:04 AM
ef8340
Sep 28, 2008 10:44 AM
Mixmastermerrill
Aug 5, 2008 02:16 AM
Mixmastermerrill
Jul 29, 2008 10:45 PM
