Where to start?
Old Jun 11, 2013 | 09:45 AM
ThomasNieman710's Avatar
Where to start?
So last monday I bought a 74 dart swinger. Shes in beautiful condition and took little to get street ready, so here's the kick. I'd like to get it on par with some of the L2 motored vehicles I see out on woodward on the weekends but I know these smaller cars don't have (too)much room and kahunas for these type of upgrades. Any and all posts are appreciated.
BTW it has a little baby slant 6 in it atm, pretty stock all around except for new wiring, tires, hoses. things I've accomplished thus far.
Old Jun 11, 2013 | 11:07 AM
Please someone tell me what direction to go. For now I'm just cleaning everything but I need a stable place to start the rebuilds
Old Jun 11, 2013 | 12:09 PM
74Runneer's Avatar
Do you plan to keep the /6 or upgrade to a v8?
Old Jun 11, 2013 | 02:22 PM
inri's Avatar
Look online to Find out if you can swap in a 360? I'm sure others before you have done an engine swap upgrade.
Old Jun 11, 2013 | 03:54 PM
inri's Avatar
FYI...I was at Walgreens earlier today and perused the magazine rack. I saw a Magazine called "Street Truck" with its cover story being an LS engine vs a 350. I thumbed through it and saw that the LS build they did had more than 500 hp. It was a pretty informative read. It cost just over $12k for the build.
Old Jun 12, 2013 | 05:53 AM
I'd definitely like to go V8. My paps has an old 383 sitting in the weeds where his rotted out 69 Cuda sits. (what a waste)
So I was thinking perhaps I could salvage whatever possible off that and attempt a rebuild? possibly bore or stroke it?
Also, I'm planning a junkyard trip for either an 8 3/4 rear end to mount or a ford 9"
Thanks guys
Old Jun 12, 2013 | 06:01 AM
V8 mate
Old Jun 12, 2013 | 06:42 AM
pro-tech's Avatar
They make motor mounts now to make the swaps so you dont have to swap the K member. But I would think you will have to change the torsion bars to handle the weight difference.
Old Jun 12, 2013 | 08:53 AM
Originally Posted by ThomasNieman710
I'd like to get it on par with some of the L2 .
I have no idea what this is supposed to mean................................
Old Jun 12, 2013 | 09:56 AM
https://www.google.com/#output=searc...w=1606&bih=643
my buddies 05' GTO has an L2 and he thinks he's hot **** lol. mopar engine though will whoop it
Old Jun 12, 2013 | 09:59 AM
The dud I bought the car from already had a big block mounting kit that I got with the car. Guess he had plans for it but never went through.
I have some friends that keep telling me to just buy a new mopar engine off of JEGS http://www.jegs.com/p/Mopar-Performa...10911/10002/-1 Instead of rebuilding though..
What are your thoughts on this?
Old Jun 12, 2013 | 11:53 AM
inri's Avatar
Thomas, I think you mean LS2. Those engines are pretty nice, but no match for a Mopar!
You'll need around 400hp or more in a 3500lb car to keep up. 500 will give you spanking rights!
Old Jun 12, 2013 | 12:51 PM
Should that be 400 to the wheels or overall when speaking horses?
Old Jun 12, 2013 | 02:52 PM
The 383 motor is doable, a tight fit. There would be a lot of parts from the Cuda that you can use since it is a 69 I think it is still an A body so the complete drive train could be used
Old Jun 12, 2013 | 04:05 PM
inri's Avatar
If you can get that 400 to the rear wheels then you got it made! Those stock LS2s come with around 400 at the fly. Some could argue they make more at the fly, and they might on certain cars, but they are probably pushing 350 or so at the rear.
Get 400 horses to the rear, (470 ish at the fly, give or take depending on a number of things). Install at least 3:55 rear gears, the manual LS2's I believe may come with 3:73's. Read up on their vehicle weights, I believe many of them (Late Model Camaro, Firebird, GTO and the like weight around 3500 or 3600 lbs. If you can get your car's weight down to the low 3000lbs you won't need so much HP and you can accelerate quicker too!
Old Jun 12, 2013 | 04:12 PM
inri's Avatar
Thomas,
I just purchased the book: How to Build Max- Performance Mopar Big Blocks by Andy Finkheimer. This book is amazing to say the least. I believe there is a similar book for Small Block Mopars as well. The books go over nearly everything on how to make more power; block, heads, porting/polishing, cams, carb, intake, exhaust, valves, accessories, tuning, ignition etc. At the very least you will learn some very important information that will definitely help your build. As well as learn what works with what for more compatibility, which makes more power. Not all parts work the same with one another, certain parts work best with other certain parts. The book helps the reader understand this.
There are a lot of little things that can be done to a Mopar to increase its HP & Torque to squeeze a little more power out of it.
Lastly, it's hard to beat the sound of the all powerful Mopar!
Old Jun 12, 2013 | 04:23 PM
inri's Avatar
The book: How to build big inch Mopar small blocks should be a great read. In my opinion they are a must read.
http://www.barnesandnoble.com/w/how-...1613250129&r=1
Old Jun 12, 2013 | 04:57 PM
pro-tech's Avatar
If you want a real Mopar muscle engine call Mike at MRL if you want to do some home work go to his web page at mrlperformance.com
Old Jun 12, 2013 | 05:11 PM
inri's Avatar
Nice! $7k will get you basically a turn key engine with 450 HP (flywheel) and 500lbs of torque!
Old Jun 13, 2013 | 04:29 AM
Exclamation
Here's another side issue that just came up yesterday.
So I finally got my tires in http://us.coopertire.com/Tires/Passe...ADIAL-G-T.aspx and they look so damn sexy on the beast. The rears are 235/70/15 which are snug but fit. The smallest size they had were 215/70/14 for the front but they seem a tad too tall for the well and the trim on the edge of the wheel well.
Does anyone know how I could lift the front just a tad? springs, wedges?
Thanks for all the responses on this thread as well guys!
Old Jun 13, 2013 | 04:39 AM
Or perhaps buy a kit or just mod the space out so I have more clearance?
jbda
Apr 1, 2013 10:22 AM
fastdakota84
Jun 25, 2010 01:06 PM
dodgeaspenrookie
Jul 18, 2008 07:28 PM
skinner1980
Jun 4, 2008 07:36 PM
