1968 Plymouth Fury III sedan
Old Apr 19, 2009 | 09:39 AM
68Fury68's Avatar
Junior Member
Heres my Ride...Big things to come 383 with a 727tranny
Black exterior ,Blue dash Blue doors , SeaFoam Green Seats LOL Grey carpet
Old Apr 19, 2009 | 10:44 AM
Polaradude's Avatar
Nice ride , giddy up, let the fun begin.
Old Oct 8, 2009 | 01:18 PM
Originally Posted by D'etroit
I have a 1968 Fury III coupe with the 383cu V8 with 4-bbl carburetor and duel exhausts (but removed and un-silenced from centre tunnel back), special camshaft 330bhp - although I suspect it more like 200bhp if that now it's 40 years odd old.
the horsepower wouldnt decrease just because of age
it is not bhp (brake horse power)
pre 72, horsepower was rated at the flywheel, which gave an inflated number
Old Oct 9, 2009 | 02:28 AM
A lot of the power depends on where the Manufacturer measures it at and where you (by you I mean anyone) do. The conditions would have to be the exact same between the two tests. Also, dynos have evolved just like everything else to give us a better idea of what a motor is actually putting out for power.
I agree that age/wear does play somewhat of a roll in the power of a motor, but it shouldn't cause the vehicle to lose ~70 HP. Dynos may not have been calibrated properly at the time, It could have been done once with a manual tranny and the second time with an auto, etc.
Old Oct 9, 2009 | 02:46 PM
Originally Posted by Stinkwheel
Are you sure? Over time as wear starts to set in and components age surely it will loose some horsepower?
I saw a TV show over here recently that dyno tested a maserati that was 35 yrs old, it actually made 186hp not the 255 it should have had.
I think age makes a difference.
you dont know if that car has been modified, how it was taken care of, etc....
here's an example
the engine in my car sat for over 9 years without even being cranked
but, the bores had oil on them, so no harm came to the block
it all depends how the car was treated
Old Oct 10, 2009 | 02:35 PM
well, this goes back to what 78D200 said
Old Oct 23, 2009 | 09:32 PM
mystarcollectorcar.com's Avatar
Hi there, I don't mean to be a swot
Your car is lovely but is a Fury I not Fury III
The engine should be either a 225cu straight six with 1-bbl Carburetor,standard camshaft and single exhaust = 145bhp
or
318cu V8 with 2-bbl carburetor, standard camshaft and a single exhaust = 230bhp
The big IF!
The chrome-work has been pulled off and do you have a picture of the back end and I know the difference between a I a II and III from sight. It is possible for the engine to be changed for another unit, but would not know why? Is there any sign that the bright-work has been removed or have you done it yourself?
Good luck with her. I love to see these old Mopars coming out of the woodwork get the piccies on and I will have a lookie for you Fury I's were high spec anyway for their day.
did the Fury 1 have the trim along the drip rail like this one and the extra trim on the B and C pillar?I sure don't remember that.
68FuryIII
Resources
Aug 31, 2014 03:15 PM
Furyous68
May 5, 2011 03:51 PM
68 Fury Rookie
May 1, 2011 05:01 PM
68plymouth383
Sep 21, 2010 06:15 AM
old_skool_1962
Sep 16, 2010 09:08 AM
