1988 tbi 318 how much is possible
Old Nov 2, 2009 | 06:11 PM
atowncris's Avatar
Junior Member
how much hp is possible with a tbi 318 money is a little issue but not completely would i be better off putting in a carb motor or putting a carb on mine i would like around 400hp i would be open to dropping in a 360 what do you think. thanks a lot for the help
Old Nov 3, 2009 | 03:25 AM
What is the motor going in for a vehicle? Also, Some states are strict about emissions so you may want to look into that if you haven't yet.
You can get 400HP out of a small block. It would be easier to get it from a 360 though than a 318. Also, if you want to keep the TBI setup, you may need to go aftermarket as I am not sure if the factory TBI can support that much power.
Old Nov 3, 2009 | 06:03 AM
atowncris's Avatar
Junior Member
its a 1988 d100
Old Nov 3, 2009 | 08:26 AM
You will either need/want to build the heads you have of buy a set of alum heads that have some rather large valves. Maybe even look into a stroker kit. I'm not sure off the top of my head who has them but that info has been said may times here on the forum.
Jarhizzy
Jul 24, 2022 10:32 AM
PressPlayOnTape
Jan 21, 2014 06:09 PM
Buffalojoe426
May 14, 2010 03:42 AM
33harner
Jun 28, 2009 10:56 PM
1988Dodge4x4
Nov 19, 2008 06:51 PM
