3 hot cylinders
Old Jun 26, 2010 | 06:57 PM
hdphilbo's Avatar
Junior Member
Question 3 hot cylinders
i just built a 500" lowdeack and i have 3 cyliders that are running hotter than the rest.they are cylinders 2,5,7. the oher five are running between 480 and 520. but 2 is over 600 and 5 and 7 are 700+.i have no idea what could be making them 3 hot like that?let me give you a little back ground on the engine.it's a 400 block over bored to 4.380.it has a 4.150 crank.440 h beam rods with ross flat top pistons.it has a hughe engines hydraulic cam with .584/.592 lift with my 1.6 hughes roller tip rockers.237/242 duration @ .050" 108 lobe seperation and comp cams magnum lifters.it has edelbrock rpm heads ported by modern cylinder heads.edelbrock rpm intake with a holley 9831 830 cfm carb.an msd 6al ignition with an msd 8545 distributor.and it has headman headers.oh and it has a pro gear 4000 series timing chain set with a 9 keyway crank gear.any ideas would be very helpful.ive already burned up a starter and it's starting to melt stuff.
Old Jun 26, 2010 | 07:07 PM
Originally Posted by hdphilbo
it's a 400 block over bored to 4.30.
I think taking over a 1/4" out of each cylinder may be the problem. (I'm thinking you have a typo).
I'm not very good with running numbers like that through my head, I'm more of a hands on fix-it kind of guy but there are some great people here who I'm sure wil be able to help you.
How are you able to measure the temperture of each cylinder? Just wondering.
Old Jun 26, 2010 | 07:36 PM
scotts74birds's Avatar
Too much timing, too lean jetting, air leak causing an over-lean condition. How does it idle and run?
Old Jun 26, 2010 | 07:42 PM
1966sportfury's Avatar
A.K.A Bob Dodge
did you have the block sonic checked? to see if the cylenders were thick enough? .030 shouldnt hurt, im not talkn about the "thin wall" myth, but ive had block that rust had ate away the inside of the cylinder
Old Jun 26, 2010 | 08:05 PM
hdphilbo's Avatar
Junior Member
i have 84 jets in front,86 in the rear.it fires right up and idles awesome.if it was lean,why are'nt all the cylinders hot.i checked the plugs,and they actually looked rich,not lean.my timing is 15 inital,36 total.
Old Jun 26, 2010 | 08:09 PM
hdphilbo's Avatar
Junior Member
had my blocked checked,it was all good
Old Jun 26, 2010 | 08:11 PM
hdphilbo's Avatar
Junior Member
buddy of mine has a laser temp gauge.the block is only bored .040".stock bore is 4.34
Old Jun 26, 2010 | 08:29 PM
was the block "decked"? How easy was the manifold install? Bolts drop right in? I'v had lots of sealing problems with my 383 and an Edelbrock Performer RPM.
Old Jun 27, 2010 | 05:45 AM
hdphilbo's Avatar
Junior Member
went on like a glove,bolts dropped right in.block was not decked
Old Jun 27, 2010 | 06:35 AM
r69cuda's Avatar
Junior Member
Just thinking out loud here. What if you try an 89 jet in the drivers side rear and an 87 jet in the pass side front. Then check your temps and see what happens. Mark
Old Jun 27, 2010 | 10:59 AM
smackhonda's Avatar
what type of headers are you running? you might want to try some equal length headers, this could be a back pressure issue. If the back pressure is different for those cylinders it might cause a different temp reading.
Old Jun 27, 2010 | 02:19 PM
hdphilbo's Avatar
Junior Member
i really dont think it's a lean condition.i pulled the plugs after 100 miles and they actually looked rich.
Old Jun 27, 2010 | 02:21 PM
hdphilbo's Avatar
Junior Member
i ran these same header on this engine with 2 other top end configurations and never had a heat problem like this.
Broker-Bob
Jul 30, 2014 09:20 AM
josehf34
17
Jan 3, 2014 06:44 PM
brianp
18
Aug 4, 2013 06:09 AM
runninbird
Nov 25, 2007 12:44 PM
