318 smog motor
Old Feb 14, 2009 | 11:44 AM
Emission laws is why.
First thing to do is see how tight your state is on emissions. If they are not that strict, then you have plenty of options as to how to get more power. If they are strict, then you are a little more limited.
Old Feb 14, 2009 | 02:36 PM
If that is the case, then you should have no problem getting some more power out of it. Breathing in and out is what that motor needs. Is it TBI or carb?
Since you have the ability to not have it emissions tested, you can do a lot then. A better set of flowing heads is the place to start. Next is an intake and carb. you might have a hard time finding a set of headers unless someone here knows where you can get some, but after that, take it to an exhuast shop and have them make you a 2 1/4" exhuast with a set of mild mufflers (don't want to atract that much attention to yourself). After all that you have ignition, tranny and rear end upgrades that you can do.
Old Feb 16, 2009 | 04:25 PM
I'm not sure what size the ports are that you have. You would probably be better off buying a set of alum heads or cast heads from a late 60s early 70 small block ("U", "J", or "X" heads).
Robert Weaver
13
Sep 29, 2014 11:33 PM
ctdfan
Nov 9, 2013 11:05 AM
Leadsled
Jan 23, 2012 08:12 AM
LittleSpark
Jan 15, 2009 09:06 PM
P0STER0CH1LD
Jan 21, 2008 12:59 PM
