440 Big Block Build
Old Nov 16, 2009 | 03:20 PM
KyleLR's Avatar
Junior Member
440 Big Block Build
Hey guys, I just got a 1975 cast 440 RB and have it down to the bare block. I wanna build it back up to make about 450 to 550 HP. I don't have a car to put it in yet but it'll be some kind of E body. I just need a list of parts that will make the power I'm lookin for. I want to to be super reliable for almost a daily driver. You guys have any suggestions?
Old Nov 16, 2009 | 04:47 PM
I would recommend TRW pistons and rods.
Will the car run on the track a lot?
If not, I recommend an edelbrock cam.
Heads- either old 60's heads or new aluminum ones (whatever your preference is)
Old Nov 17, 2009 | 07:58 AM
68 Sat's Avatar
Here is my complete list for my 440 build. It should make 450+HP and should be very reliable. 9.5/1 compressiion. This is just the engine build and does not include brackets, pumps, tranny, cooling,carb, and other misc. stuff. I should have her ready to run in a few weeks and I'll post a bunch of pics..
H142CP Pistons
82320CP10 Rod bearing set
5025MA10 Main bearing set
R92785 Piston ring set
1453M Cam bearing set
213064 Camshaft
82216 Lifter set
91104 DR timing set
2244174 oil pump
2246174 oil pump drive
FS7891PT11 full gasket set
2604035 valley pan gasket
F01 core plug set
20760 baffled oil pan
24750 oil pan pick up
2002903 flex plate bolt set
10237 flexplate
60929 alum cylinder head
2191 alum intake
1009 hp perf head gasket
MPR323 pushrod
1453606 head bolt set
MRG378 valve cover gasket
Old Nov 17, 2009 | 09:16 AM
KyleLR's Avatar
Junior Member
The car will not be at the track a lot. Maybe once or twice a year. Where did you buy all your parts from Sat? I'm really new to all this so you have to talk to me like I'm a kid, this is my first rebuild. I realize that those are part numbers, but where do I find them?
Old Nov 17, 2009 | 09:22 AM
You can get quiet a good deal on a carb, intake,, cam and gasket kit from Summit Racing (or at least you use to be able to). Couple that with a good flowing set of heads, headers/exhaust, and a good ignition upgrade and you will have a good, strong, reliable motor.
Old Nov 17, 2009 | 09:30 AM
KyleLR's Avatar
Junior Member
Originally Posted by 78D200
......and a good ignition upgrade.
What do you mean buy that?
Old Nov 17, 2009 | 10:21 AM
68 Sat's Avatar
Most of the parts can be ordered from Summit, Jegs, and the like. Go to google and type in the part number and description and start learnin.. It will be a great way to educate yourself on your build and what parts are needed..
Old Nov 17, 2009 | 10:55 AM
KyleLR's Avatar
Junior Member
None of those part numbers work on jegs.com or summitracing.com. I type them into google and the only link it gives me is back to this thread.
Old Nov 17, 2009 | 12:26 PM
Upgrade the dizzy and box to a Mopar Performance unit and Orange Box or go full MSD dizzy, wires, coil, and ignition control box. It all depends on how you plan on driving whatever you put the motor in. If it's just for cruising, I'd get the MP dizzy and OB.
Old Nov 17, 2009 | 12:30 PM
Also, I copied and pasted "213064 Camshaft" on yahoo.com and it cam up with Competition Cams 213064 Bb Chry 383-440 so you might just have to go through a couple of different search engines and maybe add a few words to the description.
Old Nov 17, 2009 | 03:37 PM
2x on that
that is what I have
Old Nov 22, 2009 | 10:55 AM
KyleLR's Avatar
Junior Member
Ok so my block is at the machine shop right now. I had to get it bored .030" over, and I'm getting it clearanced for a stroker kit. Also I got the oil pick up tube hole enlarged to 1/2".
Anyone know of a good stroker kit to put in. The biggest stroke I can go is 4.125".
I've done some reading and the consensus is, don't cheap out on the bottom end, cause it's way more work to upgrade in the future. But I still have a budget of about 4 or 5 grand.
So, great stroker kit, nice cam, and decent flowing heads. Sound good?
Old Nov 22, 2009 | 04:15 PM
dont forget intake manifold and some good headers
Old Nov 22, 2009 | 05:06 PM
KyleLR's Avatar
Junior Member
Actually I haven't really thought about that yet. Duel or single plane?
Old Nov 23, 2009 | 02:11 PM
hmm
it all depends on what you are going to do with the car
try pm'ing crazy4carz
he can definetly help you there
Old Nov 23, 2009 | 02:32 PM
KyleLR's Avatar
Junior Member
hmm
GO FAST! lol But she'll will not be on the track very often.
Old Nov 23, 2009 | 07:56 PM
John Van's Avatar
Oh you say that now but wait till you feel the power of a stroked big block! I bet you will being spending a lot more time at the drag strip!!
I know because i said the same thing!
Old Nov 24, 2009 | 12:29 PM
72RDRNR's Avatar
www.440source.com for stroker kits and heads
Old Nov 24, 2009 | 03:03 PM
KyleLR's Avatar
Junior Member
Hear anything good/bad about those kits? my machine shop guy says for the price they're probably not the best quality.
Here is the block fresh from the machine shop. .030 over and clearanced to 4.150 stroke. Had the oil pickup tube hole enlarged to 1/2" also. Gave her a fresh coat of Mopar Orange today. Man I'm gettin excited to put this thing together!!!!
Attached Thumbnails 440 Big Block Build-pb240269.jpg   440 Big Block Build-pb240270.jpg   440 Big Block Build-pb240271.jpg
Old Nov 24, 2009 | 03:25 PM
looking good!
Old Dec 2, 2009 | 09:35 AM
72RDRNR's Avatar
Have not heard much bad about them, few good things. I think there might be a few here who have used them. I think Apollo ordered one but dont think his charger is on the road yet. DeadKelly did you look into these or have one? I have ordered other parts from them and
ams happy with the parts and customer service was great.
Old Dec 2, 2009 | 11:44 AM
KyleLR's Avatar
Junior Member
Thanks a lot guys for all the info so far. I can't spend any more money until I put some more back in the account so this thread will probably be quiet till spring time when I have a truck load of parts to slam together on that block.
It's time to go make some money to pay for all the goodies!
Old Dec 2, 2009 | 01:19 PM
68 Sat's Avatar
Looks great KyleLR. Keep us posted with the pics when u can..
Old Dec 2, 2009 | 02:21 PM
  #24
2x on that
Old Dec 2, 2009 | 03:24 PM
  #25
KyleLR's Avatar
Junior Member
Will do guys! Thanks again!
pipdog69
Mar 13, 2012 11:01 PM
Nov 30, 2010 12:18 PM
68satellite
May 23, 2009 05:33 AM
Brent1960
May 17, 2009 04:25 PM
mahd
Apr 2, 2009 09:05 AM
