440 cid, combo suggestions?
Old Jun 12, 2009 | 04:01 AM
You should tray and find out who rebuilt/freshened up the motor and see what they did for internal work. If there is a 4 barrel on there for an intake and carb, then who knows what you have for a cam.
Since you want it to be streetable power, that is going to take some work. I'd look into Edelbrock's Air-Gap performance RPM intake and an 800 CFM performer or AVS carb. Alum heads will help to dispurs the heat better than the stock heads and you can have valve work done to them to increase the flow. Your going to want a good set of headers as well. Probably long tube but not too long.
A lot of this will all depend on how you have your cam ground down though.
Old Jun 12, 2009 | 06:22 PM
dont do anything until you find out what power the motor is making right now
Old Jun 13, 2009 | 02:28 PM
it probably has a forged crank in it
Sign Guy
Apr 22, 2013 10:01 AM
nesparky
Jan 29, 2011 04:42 AM
wedgehead65
Sep 24, 2010 07:54 PM
ftf
Jun 23, 2008 02:42 PM
