440 noise
440 noise
i just found a 69 block 440 out of an old stationwagon freshened it up, put in new oil pump. plastigaged the bearings put in my 533/320 purple shaft, cloyce dual roller chain, new .020 sreel head gaskets, headers and three inch exhaust. installed the engine in my 69 roadrunner and for three days it ran great. then there was a really strange crrrrrr noise from the front of the block under the distributor. i have taken the intermediate shaft out and changed it ,the noise changed to a more squeeling or singing noise coming from the same spot. i just ordered a new bushing to go under the gear but i am stumped i have owned this car for 23 years and have never had this kind of problem????????????with any of the 383s or 440s that i have had in it the dist is a brand new unilite had it checked it is fine. any help here would be greatly appreciated thanks alot neil
i have even taken the cam , lifters, valvetrain apart three times all looks good no marks or shavings in the oil???????????????? looked at the bottom end twice looks fine. but still this noise???????????? the new mopar performance bushing will be here in the morning guess i will put it in and run it again???????????????????????????????????? not much help here?????????????????????????????????????????????? ??????????????????
Could it be the dizzy? Water pump like fivepoint mentioned, maybe a different pulley?
Sounds and noises can travel through metals before being heard so they sound like they are coming from one spot when they are actually something else.
You need to grab an auto stethescope and source it. The ear cups block all the high freq noise thats bouncing all over the engine and the source noice will be blantantly obvious.
With the car running you can find small things like pin hole exhaust leaks and dry steering rack seals...
I think they are on ebay for less that 10 bucks..
