440 noise
Old 09-22-2010, 05:14 PM
44069roadrunner's Avatar
440 noise
i just found a 69 block 440 out of an old stationwagon freshened it up, put in new oil pump. plastigaged the bearings put in my 533/320 purple shaft, cloyce dual roller chain, new .020 sreel head gaskets, headers and three inch exhaust. installed the engine in my 69 roadrunner and for three days it ran great. then there was a really strange crrrrrr noise from the front of the block under the distributor. i have taken the intermediate shaft out and changed it ,the noise changed to a more squeeling or singing noise coming from the same spot. i just ordered a new bushing to go under the gear but i am stumped i have owned this car for 23 years and have never had this kind of problem????????????with any of the 383s or 440s that i have had in it the dist is a brand new unilite had it checked it is fine. any help here would be greatly appreciated thanks alot neil
Old 09-23-2010, 09:10 AM
i have even taken the cam , lifters, valvetrain apart three times all looks good no marks or shavings in the oil???????????????? looked at the bottom end twice looks fine. but still this noise???????????? the new mopar performance bushing will be here in the morning guess i will put it in and run it again???????????????????????????????????? not much help here?????????????????????????????????????????????? ??????????????????
Old 09-23-2010, 06:45 PM
fivepoint's Avatar
If you did not see any signs of wear or damage, are you looking in the right spot? This may sound like a dumb question but, are you sure its not the water pump?
Old 09-24-2010, 03:01 AM
Could it be the dizzy? Water pump like fivepoint mentioned, maybe a different pulley?
Sounds and noises can travel through metals before being heard so they sound like they are coming from one spot when they are actually something else.
Old 03-29-2012, 02:38 PM
Imfast101's Avatar
Literally just had that problem with my 64 880. Check out YouTube. Type in 64 880 engine noise. Should come up. I was trying all kinds of stuff, changed pump, presto.
Old 03-29-2012, 06:31 PM
PK1
PK1's Avatar
You need to grab an auto stethescope and source it. The ear cups block all the high freq noise thats bouncing all over the engine and the source noice will be blantantly obvious.
With the car running you can find small things like pin hole exhaust leaks and dry steering rack seals...
I think they are on ebay for less that 10 bucks..
Old 03-29-2012, 07:53 PM
I agree with the stethoscope. Also remember down there is your fuel pump pushrod down there also. You could pop out you fuel pump then the rod and check it out.
Old 03-29-2012, 08:53 PM
ALso remember the fan will bite you if you are not careful
dkruk
10-17-2013 10:29 PM
Imfast101
20
03-30-2012 09:32 PM
doug2060
08-28-2010 04:33 PM
MichaelSB
08-16-2010 12:08 PM
mopar nate
03-21-2009 09:16 PM
Quick Reply: 440 noise
