4bbl throttle linkage.
Old Apr 2, 2009 | 10:14 AM
craveman's Avatar
Senior Member
does anybody have a pic of a 4bbl throttle linkage. im converting my old 2bbl and i cant find any 4bbl mopars around here anywhere and i dont know which part i need. I know i have to make the kickdown linkage longer which i can do with some couplers and threaded rod.
Old Apr 3, 2009 | 01:28 PM
69Fury3's Avatar
Why don't you just get a new kickdown cable (like $70 from Summit) instead of messing with lengthening your current kickdown?
Old Apr 3, 2009 | 01:31 PM
craveman's Avatar
Senior Member
actually i found out my stock bracket would work on this carb. i made my kickdown cable for 3 bucks and it looks pretty good. i have to cut a hole in my hood to fit the air cleaner on though.
Old Apr 3, 2009 | 01:36 PM
69Fury3's Avatar
Maybe use one of the ultra low profile foam Edelbrock air cleaners (EDL-1002)
Old Apr 3, 2009 | 02:39 PM
is this car your daily driver?
why cut the hood?
Old Apr 3, 2009 | 05:49 PM
craveman's Avatar
Senior Member
yeah
Old Apr 3, 2009 | 05:50 PM
craveman's Avatar
Senior Member
cause then i can put in a cowl. i have another hood for when i eventually put in a 4bbl that doesn't sit so high
Old Apr 3, 2009 | 06:51 PM
oh, ok
i'm just worried about when it rains
Old Apr 3, 2009 | 08:55 PM
craveman's Avatar
Senior Member
if i put in a cowl it should be fine. im gonna put a lip around the base of the rear opening so water doesnt run into the hole
Old Apr 4, 2009 | 09:32 AM
good idea
jabo51581
Dec 21, 2013 07:09 AM
degausser86
Jul 29, 2012 09:08 PM
BuckNeccid
Apr 14, 2011 10:11 PM
67Polara
May 19, 2010 06:17 PM
67Polara
Mar 1, 2010 10:12 PM
