5th ave electrical issues
Old Sep 19, 2009 | 05:30 PM
craveman's Avatar
Senior Member
ive got an 85 5th ave with a 318 in it. having some electrical difficulties at the moment. when i turn the heater on it runs for a little while and blows the fuse for the turn signals. except the heater keeps going. any ideas? need to fix soon as its getting colder now.
Old Sep 19, 2009 | 05:44 PM
theomahamoparguy's Avatar
Wow, that does not make sense at all, {leave it to the Craveman to come up with that} Anywho, can you tell if any monkey business has occured in the vicinity if the fuse block itself. [like extra wires coming out of it that do not look factory]??
I would change the flasher unit just for grins {hey its cheap}
check for continuity on the blower motor wires. Does the switch itself function correctly, low, med, high.?
Old Sep 19, 2009 | 06:30 PM
scotts74birds's Avatar
Does it do it when you run the A/C. Yeah, I know I'm reaching, but ya gotta think outside the box. And x2 with Omaha.
Old Sep 19, 2009 | 07:44 PM
Crazy4Carz.Com's Avatar
Your heat control is cable activated. Move the "hot" - "cold" lever/**** to cold and see if it does it. the cable may be pinching a wire. Run the heat but run it with the setting to cold air. see what happens.
Old Sep 19, 2009 | 11:54 PM
craveman's Avatar
Senior Member
flasher unit is fine. turn signals dont need to be on to use. i tried moving the temp control and still blows. my car doesnt have ac anymore. tried running it on the other settings. it does work in low med and high. fuseblock looks fine. wth!?
Old Sep 20, 2009 | 04:56 AM
OutlawCuda's Avatar
Senior Member
Sounds like its time for the wire diagram. Do you have one ? If you do but are not sure how to use it share it with us and we can go from there.
Old Sep 20, 2009 | 05:48 AM
craveman's Avatar
Senior Member
no dont have a wiring diagram. thinking of wiring my turn signals from the main ignition feed through a fusable link into push buttons. under dash wiring is a mess! so many wires.
Old Sep 21, 2009 | 08:26 PM
craveman's Avatar
Senior Member
i put a toggle switch in the wire for the turn signal controls. when i need heat i turn it off until i need to turn then i shut off the heater and turn them back on.
Old Sep 21, 2009 | 08:27 PM
craveman's Avatar
Senior Member
i put a toggle switch in the wire for the turn signal controls. when i need heat i turn it off until i need to turn then i shut off the heater and turn them back on. also my highbeam lowbeam switch broke so its on higbeams all the time. had to put in a toggle switch on the highbeam lights so i dont blind people.
craveman
Aug 12, 2009 03:04 AM
craveman
Apr 9, 2009 04:31 AM
craveman
Mar 11, 2009 02:19 AM
Doc
Jul 24, 2008 06:02 PM
AirBorne
Apr 19, 2008 04:02 AM
