64 318 premium
Old Jan 7, 2011 | 05:12 PM
dodge6x6x6's Avatar
64 318 premium
Is this engine worth rebuilding? its out of a 64 1 1/4 truck that was on a military base it has the big 6 lug lug nuts 4 speed and the twin stick t-case
Old Jan 7, 2011 | 06:21 PM
1966sportfury's Avatar
A.K.A Bob Dodge
its just a wide block. is it a 2bbl or 4bbl?
Old Jan 7, 2011 | 06:25 PM
dodge6x6x6's Avatar
2 bbl
Old Jan 13, 2011 | 01:19 PM
challenger's Avatar
I wouldnt really rebuild it but im sure if you try and sell it some one might want it to put in there original car/truck of that year and if im not wrong it only had about 160 hp so you would have to do some mods to get it up in hp <ijs>
Old Jan 13, 2011 | 08:06 PM
A.K.A Bob Dodge
230 i think
Old Jan 14, 2011 | 12:42 AM
theomahamoparguy's Avatar
one think you should check. some of these engines had the HD forged crank. If It has eight bolts on the flange of the crank (like a hemi). Called a 318-3 truck crank. If it has this, the crank is worth more than the engine. The strongest crank mopar made for a smallblock. Even stronger than a 340 forged crank. will spin to 9000 rpm's.
The only problem is I am not sure what year they started putting them in trucks.
It will be a forged crank non the less even if it is not the "truck-crank".
If it is the truck crank, its like the holy grail of small block cranks. I guess the only way to tell would be the eight bolt flange.
Old Jan 14, 2011 | 02:07 PM
That's a poly-318 workhorse engine you have...do some research on it....my 68 LA-318 was rated at 230 hp...they put those poly-318's in school buses with gigantic 2-barrel carbs on them...non of the engine parts are interchangable with later year LA-318's
Old Jan 14, 2011 | 03:37 PM
A.K.A Bob Dodge
except the crank,rods,oil pump, distributor,balancer,
bbyeater
Jul 13, 2012 09:16 AM
hcharles
Feb 5, 2011 03:52 PM
TallChris
Dec 1, 2010 03:29 PM
LittleSpark
Jan 15, 2009 09:06 PM
ProEmaster
Jun 6, 2007 11:31 AM
