68 318 intake installition?
Old Jul 17, 2010 | 12:39 PM
flathead31coupe's Avatar
Member
what do u do with the tabs from the head gasket on each end, when u put on the intake end gaskets, their is a opening on each end of the intake end gaskets...do the tabs go through these holes, and gwt bent over or what?
Old Jul 17, 2010 | 06:51 PM
1966sportfury's Avatar
A.K.A Bob Dodge
im not clear on the tabs your talking about, i never had to bend any intake gasket, if they were to be bent the factory would do it, 1 slight bend could cause it not to seal,
Old Jul 17, 2010 | 07:36 PM
Member
there are tabs at the ends of the head gaskets, that are in the way of the two end, intake gaskets...
Old Jul 17, 2010 | 11:52 PM
Member
Old Jul 18, 2010 | 10:54 AM
Member
thanks i got it
Old Jun 17, 2014 | 11:57 PM
Jakob Verner Edvardsen's Avatar
Does anyone cut these tabs off for a better seal?
Old Jun 18, 2014 | 01:33 AM
The tabs fit through the hole in the end seals an hold them in place. Removal will be of no benifit
Old Jun 18, 2014 | 04:22 AM
The reason I am asking is that I don't use end gaskets for my intake. I am using an Edelbrock Air-Gap intake manifold and Edelbrock write that one should use RTV sealant instead of cork or rubber gaskets because of the smaller gap between the manifold and block. Therefore I think it would be easier til seal if the tabs were removed?
Old Jun 18, 2014 | 07:44 AM
I would agree. I haven't used end seals since the mid 70's when RTV became popular
rcknrolfender79
Mar 11, 2013 07:52 PM
waham87
Feb 22, 2013 06:46 PM
LERaven
Sep 21, 2009 08:23 PM
aftrmath99
Apr 12, 2009 06:04 PM
kszysio
Mar 6, 2008 05:39 PM
