69 dart electronic ignition
Old Sep 29, 2008 | 03:32 AM
ef8340's Avatar
Senior Member
hi tish
welcome to the forums
1st off throw that blue box in the trash or better yet have a semi truck run it over im assuming thats what came in the kit it is also what advance auto offers ,..... it is junk [ thats what i think ] and order the orange or chrome one , recheck your wiring i'll be able to take some pics of my wiring later on today as my 70 dart is in the shop getting the alignment done
Old Sep 29, 2008 | 02:23 PM
ef8340's Avatar
Senior Member
okay tish cant get ya a pic but the wiring harness coming off the brain box the black with gray tracer and the brown with a white tracer is going to the dist the blue/yellow tracer is going to the ballast box[white ceramic box ] then the last one should be heading to the coil not sure on the color your ohm resistance on the ballast should be around .5 ohms using stock set up both of your blue wires going to it splice the other blue with yellow tracer in with that thats how mine is set up you dont need to use the 4 pin ballast unless you want a backup besides the one in the glove box
i hope this helps if not i'll fire up the camera and take some shots
Old Oct 20, 2008 | 05:43 PM
challenger's Avatar
are you sure the dist. is in correctly as you can still get spark with it in wrong
1966DartConvertible
May 13, 2012 08:11 PM
Duster703404
Nov 11, 2008 06:40 PM
68 Sat
Nov 11, 2008 11:05 AM
318dart
May 20, 2008 12:14 AM
theaspenator
Jan 30, 2008 06:30 PM
