A-727TF rebuild troubleshoot help
Old Jun 16, 2010 | 08:57 AM
Drakovich's Avatar
I have a 1970 Plymouth Fury III with 318 and the transmission specified in title, i am in process of rebuilding the 727tf however having some difficulty with the disassembly having never done a rebuild before im not sure if im missing something or there is something wrong with tranny.
The problem: per instruction manual after having taken off the pump and the kickback band i should be able to pull on the input shaft and the shaft along with the front and rear clutch retainers should slide out as an assembly, however the shaft and rear assembly are stuck and no amount of force will pull them out though the front retainer slides right off the shaft. so question is did i miss a snap ring or bolt omewhere locking this in place?
side note: taking the governer off and trying to slide both input and output shaft together along with the clutches in between does not work either.
Old Jun 16, 2010 | 09:16 AM
Have you pulled the valve body out yet? I think that there is a large "snap ring" that holds them in....... could be wrong though, it has been quite some time since I have had a 727 apart.
Old Jun 16, 2010 | 09:26 AM
Polaradude's Avatar
http://www.tcsproducts.com/file_libr...0Schematic.pdf
and this one.
http://www.allpar.com/mopar/transmis...-tom-hand.html
Old Jun 16, 2010 | 09:46 AM
Drakovich's Avatar
iv taken the valve body out and released+removed the large kickdown band that goes around the front cluth and theres a rear kickdown band that iv released but cannot remove until the parts that i am unable to get out are removed.
the toms hand guide really doesn't have a section on the input shaft where I'm having the trouble i only really see the output shaft section that comes after. the other link to the hand drawn schematic im having a hard time finding a peice that would hold it in on from the picture.
Old Jun 16, 2010 | 10:34 AM
Commando's Avatar
I will consult my manual if you still haven't figured it out by the weekend, but if you post some pics of what you have left together, we may be able to see what is holding you up.
Old Jun 16, 2010 | 02:08 PM
Buffalojoe426's Avatar
I videoed the the rebuild of mine, I'm trying to find out what I did with the DVD now. Ill see if i can find it by tonight and see if it would help.
Old Jun 16, 2010 | 06:25 PM
Drakovich's Avatar
well i found a guy that lives nearby and works on the Chrysler proving grounds he said that its all kinds of messed up in there and i was right in that its supposed to slide right out, but theres stuff grinding in there and its welded itself together so hes gonna break it apart for me and we gonna go from there but most likely its more than a simple rebuild kit fix.
Old Jun 16, 2010 | 07:22 PM
blue 68 gts's Avatar
Once you have the pump out and the band out, you'l see the drum, shell, shafts, ect.
Theres a snap ring that holds the input shaft on. Slide it off, and a few things will slide out.
I believe there is another snap ring inside you have to take out then the whole thing should just come out.
Theres also a snap ring holding the tailshaft on, and one holding the output shaft on
buttton
Oct 13, 2012 07:16 AM
blazo
Jul 14, 2012 07:17 PM
73' Dodge Dart
Sep 8, 2010 11:57 AM
MrMopowered
May 9, 2009 11:31 AM
1970ChallengerSE
Mar 16, 2007 10:20 AM
