73' Dodge Dart ignition problems
Old Jul 4, 2012 | 12:48 PM
73'DartKid's Avatar
Hello everybody. New to the site. Hope this is an ok spot to post. I have a problem regarding my 73' 318 Dodge Dart Swinger.
The car starts and runs fine, but when I go to turn it off, it won't. The car is in park and the key is all the way off and out, car continues to run.
I've been killing it by pulling the main coil out of the distributer, but then I also have to disconnect the battery because everything stays hot/ON. I really am pretty new to working on mopars.
Hopefully somebody can point m,e in the right direction. I can turn wrenches. Thanks in advance guys.
BTW, car sat for 8 years before I rescued it, when shes running she runs like a champ.
Old Jul 4, 2012 | 01:10 PM
Someone might have the ignition run circuit jumped out.
Old Jul 4, 2012 | 09:11 PM
73'DartKid's Avatar
I'm not completely sure what that means. I'm sorry. Where in regards to something (ignition switch, distributor, ignition resistor, etc.) would that be located near? Thank you.
Old Jul 4, 2012 | 10:09 PM
moparted's Avatar
does it shut off if u wiggle the switch?
Old Jul 5, 2012 | 07:50 AM
73'DartKid's Avatar
No it doesn't.
Old Jul 5, 2012 | 10:50 AM
Need more details. Did you just buy it? Had it BEEN operating OK?
Have you made any wiring changes? Any reason to suspect a short? Have you smelled any burnt wiring or other odd smells, or seen any smoke which might be from wiring?
My first thought, if no one has been messin' with the wiring, is that you have a bad IGN switch
To see if it's the switch, pull the small trim piece off below the steering column, and access the switch connector. There are two, one for the turn signal, and one for the switch. Wiggle the connector loose so that you can disconnect it, and start the car, then pull the connector apart. If the car shuts down, you have a bad switch.
If the car runs with the switch disconnected, you have a short in the wiring.
You have a shop manual? By that I mean a FACTORY Chrysler shop manual? You need to get one.
Old Jul 5, 2012 | 12:19 PM
73'DartKid's Avatar
---Yes i just bought it a couple weeks ago. And no it had been sitting in the hills for 8 years. However, I brought it home on a friday, and I started it the next day after replacing the fuel line and fuel filter. The ignition switch worked fine until I drove it for the 1st time. Then it messed up.
---I myself have made no changes to the wiring, however I have noticed a few wires snipped here and there, as well as the fuse box/panel was hanging down by the wires. So saying that a short could very well be possible. I have not smelt any wires burning or melting. BUT I did remove the panel (you mentioned) yessterday and noticed that the large red wire had been either rubbed raw or slowly melting over the years, so I covered the entire wire harness with electrical tape. Still having the issue.
---Then that might be it, because I tried unplugging both harnesses, and the car continued to run, I also removed all the fuses (not sure if any of them tie into ignition?) but that didn't kill the motor either.
---Yes I know I need one, I can only find the "HAYES" repair book, It covers a ton more cars than mine though and i'm thinking that might not help me with the issue im having. I don't know.
---Thanks so much for the advice, I hope you continue to help out.
Old Jul 5, 2012 | 03:33 PM
MrOldart2U's Avatar
You are right, the late hayes books are crap, one of the old Motors Manuals would be great ( no longer in print ) but there is hope here.... Manual on CD
Or Here:In Print
Not that we will not help, but do the test the 440 suggested first and report back in the mean time...
Old Jul 8, 2012 | 08:57 AM
73'DartKid's Avatar
hey guys, so I decided to go with hayes, I know i know, they aren't the best out there. But I bought a couple used ones for 25 bucks. I ordered the "67'-76' Dodge Dart/Plymouth Valiant" and the "Chrysler engine overhaul, V8 & 3.9L". Hopefully with the 2 manuals I will be able to get a good coverage over the car. They should be here by the 18th. Let me know what you guys think. Thanks again guys. Don't forget about this thread, haha, i'm sure i'll still need some help from the pros here. haha thanks again guys.
Old Jul 8, 2012 | 09:50 AM
blue 68 gts's Avatar
DO THIS. It'll take you less then 5 minutes to figure out if you need a new switch or harness (or wiring repair).
Old Jul 8, 2012 | 11:03 AM
hey guys, so I decided to go with hayes, I know i know, they aren't the best out there. But I bought a couple used ones for 25 bucks..
I wish to heck you would have said something before you did that. I didn't pay much more than that for my 67 Manual on CD. I was recently at a carshow and bought a used/ good shape ORIGINAL printed manual for 74 (for reference) for 35 bucks.
For less than 50 bucks you can buy a manual on CD several places on the www. Including eBay. You can also buy reprints of the factory manual.
Where do you think Haynes and others get their info? BUT they leave a LOT of stuff out, and there is nothing in there about many, many things which are in the factory manual. YOU NEED a factory manual if you are SERIOUS about driving and maintaining one of these old girls.
Old Jul 8, 2012 | 11:06 AM
73'DartKid's Avatar
I have. I stated in one of the above post.
Old Jul 8, 2012 | 11:14 AM
73'DartKid's Avatar
I know. Poor people got poor ways. haha I figure worst case scenario is I spend another 30-40 bucks for the original manual, and just have more references. There's always more than 1 way to get a job done.
Old Jul 8, 2012 | 12:21 PM
I didn't see that you answered that, because you answered it inside of a quote.
Old Jul 8, 2012 | 01:13 PM
73'DartKid's Avatar
i know i apologize. i meant to do it as a multiple quote. i didn't succeed. haha
Old Jul 10, 2012 | 04:58 PM
73'DartKid's Avatar
So this seems to be the issue, the wire run to the alternator, you can see in the pics that it had corrosion, and a lot of bare wire showing, I just cleaned it up and replaced the electrical tape. Car starts and shuts off just fine now. Thanks everybody.
Closer up. Its the middle black wire.
Old Jul 10, 2012 | 05:03 PM
73'DartKid's Avatar
Of course though, with every problem fixed, a new one appears. I recently took it for a little drive around the block, and it started to hesitate and die while I throttled it. Once it dies though, i could put it and neutral and it would fire right back up. It did this 3 times in a mile run around the block. What I noticed is, I could tap and tap and tap the throttle and it would work ok. But if a hammered down, shed putt out and die, almost like she was flooding...or starving. I'm not sure.
Somethings you guys should consider when responding... The car has sat for 8 years. I did pull the tank and empty it, replaced the inline fuel filter. The spark plugs are hideous. I'm thinking that maybe the old fuel is still in the lines and jets and it just needs to be burnt out. Any suggestions would be great. Thanks guys.
Old Jul 11, 2012 | 08:09 AM
MrOldart2U's Avatar
I would say a carb tear down and rebuild... Probably varnished up... And new plugs if they are as bad as you say they are.
Old Jul 11, 2012 | 01:06 PM
73'DartKid's Avatar
Ok thanks. I figured it would be something to do with the fuel. The spark plugs are just really gunked up, I think the last owner tried running it with some of that good ol' aged gas. haha I'm wondering if the fuel filter should be removed and just checked for clogs. It's literally not even 2 miles old.
Also, she started back firing a little bit at higher RPMs...timing? Or possibily the same issue with the unexpected dieing?
Thanks again everybody.
stanthemoparman
Apr 14, 2020 10:41 PM
xvodysseusvx
Jun 25, 2018 04:38 PM
12caguamas
Apr 15, 2015 01:48 PM
AZDODGEMAN
Apr 11, 2011 12:39 PM
alsparl
Jul 7, 2009 03:39 AM
