750 dual line carb on a 440
Old Dec 16, 2008 | 02:52 PM
BuckNeccid's Avatar
I've always just slightly bent the fuel line upward, clear the distributor.
Old Dec 16, 2008 | 07:33 PM
challenger's Avatar
I would go to atleast a 1" spacer if you can clear everything like the hood and all , it will help stir up the fuel better for a little bit more hp and take off
Old Dec 17, 2008 | 03:35 AM
A spacer will work but it kind of depends on what style you get. A 4 hole spacer is better for low end while a single hole is better for mid to top end.
Old Dec 17, 2008 | 04:57 AM
Commando's Avatar
Before you go the spacer route, make sure the hood will close with the increase height. If you do not know how to test this, take pieces of clay and roll it up a bit so there are little towers on top of your air cleaner and close the hood and then measure the ones that got squished and thats how much clearance you have.
Old Dec 17, 2008 | 01:33 PM
x2 on that
440Mag
Nov 18, 2014 06:00 AM
76 Doba
Apr 9, 2013 11:00 AM
2002ram440
Dec 1, 2011 12:00 PM
76 Doba
May 26, 2011 02:24 PM
dodgenut7
May 25, 2010 10:34 AM
