Milodon dual line oil system problem
Old Nov 17, 2014 | 06:01 AM
440Mag's Avatar
Hi!
I have milodon dual line oil system in my RB wedge. As you can see from this pic; shorter oil line(which leaves back of the pump) is in front of motor mount.
Can I just put AN12plug in that output and use only one line?
Or what..?
Attached Thumbnails Milodon dual line oil system problem-10517641_759267924157700_3019818296956929820_o.jpg
Old Nov 17, 2014 | 08:44 AM
I think two is for higher RPM cars. I'd check their catalog or instructions to be sure.
Old Nov 17, 2014 | 11:36 AM
moe7404's Avatar
i think that system has two suction lines. to get more oil to the pump, at high RPM. and running thicker oil is a factor. oil pumps weakest thing is the suction lines. I.E. a pump doesnt pull as good as it pushes. if the inlet to the pump will still get enough oil with one inlet, you might get by with one inlet. if your RPM is a little lower than a race engine, and thiner oil, you should get by with one inlet. my guess is the fitting going into the pump housing is an"O"-Ring boss. an good hydraulic shop should have a plug for the pump housing
Old Nov 17, 2014 | 11:52 AM
440Mag's Avatar
I know that dual line system is recommended for 7500rpm and over, but my engine will not never see more than about 6500rpm.
One AN12 line will be ok, but is there any technical reason why I should not plug another oil line?
I'm from Finland and my english is not very good, but I hope you understand what Im meaning
Old Nov 17, 2014 | 01:11 PM
A technical reason would be if you had more bearing clearance like in a race motor. There would be a larger volume coming out of the bearings and this would help to cool them as well.
Old Nov 17, 2014 | 01:20 PM
440Mag's Avatar
Yea, but I meant if there is something related to the oilpump and how it works with that milodon's top cover.
Edit:
I've run this same engine before with milodon's 1-line oil system and it works with no problems. Main clearance is .003". But that 1-line system went to one of my other engine and I bought this used 2-line for this 499ci.
Old Nov 17, 2014 | 06:13 PM
Mr.4spd's Avatar
I'm pretty sure the single line cover is the same but comes with the extra port plugged. I'll look tomorrow if I remember.
Old Nov 18, 2014 | 06:00 AM
I'm sure you could cap that side.... Just be careful of the RPM range... Don't starve it of oil....
keylargo
Jan 10, 2014 05:12 PM
trenseter
Sep 6, 2013 04:49 PM
3rd1970RR
Oct 14, 2012 04:28 PM
raycer5
Dec 17, 2008 02:22 PM
dzltd02
Oct 28, 2008 08:25 AM
