833 Transmission stuck in Gear
Old Aug 9, 2009 | 08:52 AM
theomahamoparguy's Avatar
Originally Posted by Derek Dunne
My 73 Duster is stuck in gear. However it seem to be able to go in reverse. Can anyone provide me with a solution?. In the last couple of months I installed a new 833 transmission.
Thanks
Derek
most likely the linkage is not adjusted correctly or it slipped out of adjustment. where did you get the trans from? did you use a new shifter and linkages? does the clutch work good?
98 SNAKE EATER
Jun 19, 2013 06:22 PM
67 GTX
Nov 16, 2009 02:30 PM
1cerberus4u
Apr 18, 2008 06:55 PM
panelman
Feb 18, 2008 11:44 AM
unit_121
Dec 6, 2007 05:04 PM
