85 gran fury rearend
on
i guess the stock 7 1/4 rearend couldnt handle the abuse of my 17yr old little brother!![EEK!](https://moparforums.com/forums/images/smilies/eek.gif)
We called all the junkyards within 150 miles and still cant find any 80s furys, dippys, new yorkers, or fifths.
So the question is are there any other mopar rearends that will easily fit under the beast without major mods?
Did any of the 80s light duty trucks use the same rearends?
thanks
thanks
where in IL are you? and I would go with an 8-1/4 that was in some of these cars, 2.9-3.2 would be good for daily driver duty.
I scrapped 4, good (not mechanically "broken") 7-1/4s a few years ago; I couldn't even get $25/ea, drum to drum out of them. 7-1/4s are weak junk from the word "go",
all 4 of these were from Aspens/Volare's a direct swap to your car.
Go with the 8 1/4, it "should" last longer. Make sure to go through it though before installing it and make sure that your bearings and ring and pinion all look good.
