85 gran fury rearend
Old Jan 10, 2010 | 12:12 PM
getsum's Avatar
i guess the stock 7 1/4 rearend couldnt handle the abuse of my 17yr old little brother!
We called all the junkyards within 150 miles and still cant find any 80s furys, dippys, new yorkers, or fifths.
So the question is are there any other mopar rearends that will easily fit under the beast without major mods?
Did any of the 80s light duty trucks use the same rearends?
thanks
Old Feb 10, 2010 | 04:44 PM
volaredon's Avatar
Member
where in IL are you? and I would go with an 8-1/4 that was in some of these cars, 2.9-3.2 would be good for daily driver duty.
I scrapped 4, good (not mechanically "broken") 7-1/4s a few years ago; I couldn't even get $25/ea, drum to drum out of them. 7-1/4s are weak junk from the word "go",
all 4 of these were from Aspens/Volare's a direct swap to your car.
Old Feb 10, 2010 | 07:52 PM
getsum's Avatar
we found an 81/4 for it and yes the 71/4 was junk. my other brother had the same kind of car and blew out 2 71/4s in 5 years.
Old Feb 11, 2010 | 03:22 AM
Go with the 8 1/4, it "should" last longer. Make sure to go through it though before installing it and make sure that your bearings and ring and pinion all look good.
Old Feb 11, 2010 | 06:11 AM
volaredon's Avatar
Member
just DON'T get one with a 2.26 or a 2.41 gear! want to talk about a
"doggy", gutless car!
theomahamoparguy
Mar 15, 2010 09:46 PM
FuryGC
Oct 30, 2009 12:54 PM
FuryGC
Oct 24, 2009 05:11 AM
chavlics
May 29, 2009 02:36 AM
ameyrick
Sep 8, 2008 08:27 AM
