86 318 cam
Old Aug 17, 2009 | 07:38 PM
theomahamoparguy's Avatar
Originally Posted by ryan_e
got a question for you guys, can you swap out a hydraulic roller cam with a hydraulic flat tappet cam or would it not match up right to the block?
Im going to assume that this is an early roller motor with LA heads.
yeah you can do that, I think the only diff. in the block are the lifter bores are taller. The bores are at the same angle and they have the same diameter. you will have to use the corresponding pushrods. {the ones for hydraulic flat tappet LA style, if this is a magnum, might have to get them aftermarket}
Why do you want to change to the hyd. flat tappet?
Satellite72
Apr 11, 2011 08:01 PM
hendrick4825
Feb 16, 2011 10:06 AM
Jay
Jun 3, 2010 10:24 PM
deadkelly
Aug 30, 2009 07:24 PM
reilly
Apr 25, 2009 08:47 PM
