Carb linkage
Carb linkage
Hey guys, getting closer here. I have a Speed Demon 750 vac secondary on an Eddy Performer RPM intake, on a 383. What setups have you used for linkage brackets and kickdowns? The factory bracket doesnt like the high rise, and I dont have a clue on how to connect the kick down to the carb. Would like to get a kit if possible. I've seen some in the mags, but word of mouth is best. Thanks guys
I have use Lokar before. They are well known and do make a good product. Although the directions can be a little difficult to understand sometimes. I would spend the money on that, fabricate a bracket for the kick down and throttle cables and have someone how has installed them before give you a hand. If you don't know anyone, ask around locally and see who people recommend to install the kickdown cable for you. If it is not installed properly, you can damage your tranny.
1968newport
01-06-2015 07:04 PM
