Coolant leak
Coolant leak
I was installing some ignition wire brackets and when I started to remove the front right header stud from the engine, alot of coolant began leaking out. I'm a novice mech, but I'm pretty sure coolant should not be there. Any ideas of what could be wrong would be much appreciated. Thanks
I take it that its probably the first stud.
That is normal. The stud actually plugs that water passage. I've used that stud to drain fluid from the heads before removing them so that I wouldn't get (or get less) coolant all over the place when I pulled a head off.
i found this out when i put headers on my fifth ave. the front and rear stud on both sides will drain the coolant. the header instructions didnt say to drain the coolant first but its nothing to worry about.
coolant
Hi Marky,
I asked the same thing when i was changing the gasket on my
72 cuda !
But be careful because my end bolt snapped off in the head
and i had to drill it out and re-tap the threads !!!!
cheers,Neil
72 cuda !
cheers,Neil
hey cuda, thats a bitch aint it, happened to me too , drivers front stud. just flush with head. had no trouble getting it out, then went to finish rest of studs and the back 1 broke too lol. I was pissed. of course its power brakes, of course its big tube headers, of course teh steering shaft runs right next to it. was the last part of the install too, didnt want too pull the motor again, had to use a right angle drill adn get it out, after 2 hrs, Id been better off to pull the motor,next time I know better, no more headers.
