Coolant leak
Old Mar 19, 2009 | 06:56 PM
MarkyMark12345's Avatar
Member
Coolant leak
I was installing some ignition wire brackets and when I started to remove the front right header stud from the engine, alot of coolant began leaking out. I'm a novice mech, but I'm pretty sure coolant should not be there. Any ideas of what could be wrong would be much appreciated. Thanks
Old Mar 20, 2009 | 01:13 AM
I take it that its probably the first stud.
That is normal. The stud actually plugs that water passage. I've used that stud to drain fluid from the heads before removing them so that I wouldn't get (or get less) coolant all over the place when I pulled a head off.
Old Mar 20, 2009 | 02:35 AM
Polaradude's Avatar
No worries, water jacket.
Old Mar 20, 2009 | 07:37 AM
Member
That just made my day Someone told me it might be a cracked head. Thanks for the help guys
Old Mar 20, 2009 | 12:18 PM
Crack that person's head for say that. (lol don't really) But yes put a thread sealer compound on that stud before reinstalling it. And don't forget to top off your cooling system.
Old Mar 23, 2009 | 09:02 PM
craveman's Avatar
Senior Member
i found this out when i put headers on my fifth ave. the front and rear stud on both sides will drain the coolant. the header instructions didnt say to drain the coolant first but its nothing to worry about.
Old Mar 24, 2009 | 02:53 PM
Member
haha I'm not too sure my little brother would like that too much. He's the one who got me into the car scene
Old Mar 26, 2009 | 02:34 AM
cudaneil's Avatar
coolant
Hi Marky,
I asked the same thing when i was changing the gasket on my
72 cuda !
But be careful because my end bolt snapped off in the head
and i had to drill it out and re-tap the threads !!!!
cheers,Neil
Old Mar 28, 2009 | 11:30 AM
rr69half6bbl's Avatar
hey cuda, thats a bitch aint it, happened to me too , drivers front stud. just flush with head. had no trouble getting it out, then went to finish rest of studs and the back 1 broke too lol. I was pissed. of course its power brakes, of course its big tube headers, of course teh steering shaft runs right next to it. was the last part of the install too, didnt want too pull the motor again, had to use a right angle drill adn get it out, after 2 hrs, Id been better off to pull the motor,next time I know better, no more headers.
Old Jan 30, 2010 | 06:14 PM
DodgeW200's Avatar
What would you recommend for a sealant in this situation? Mine is leaking after a heli-coil instalation.
Old Jan 31, 2010 | 09:30 AM
John Van's Avatar
Any high temp silicone sealer will do
hckrphil
Jun 17, 2014 09:53 AM
Rumblefish318
Jul 31, 2012 06:14 AM
77Aspen
Jul 11, 2011 02:17 PM
pjjaramillo
Aug 30, 2010 11:22 AM
64fury
Sep 5, 2008 06:32 AM
