Correct Spark Plug &Gap
Old Jun 7, 2010 | 09:04 AM
H-Pattern's Avatar
Was wondering the correct spark plug (Autolite) and gap.
72-340. Motor was bored .30 over has a 4 inch stroker and a 508 purple cam. Top end has Edelbrock preformer heads and a offenhauser intake.
Thanks.
Old Jun 7, 2010 | 09:25 AM
Barfly's Avatar
.035 on a stock motor I'm pretty sure. With all your mods that could be off I don't know.
Welcome to the forum!
Joe.
Mopar motors like Champion plugs. I know, I know. You would think that it doesn't make that much difference, but it does. As far as gap goes, i'm not sure. A lot of it will depend on what you are running for an ignition.
Old Jun 7, 2010 | 09:34 AM
H-Pattern's Avatar
Ignition is stock Mopar electronic.
Thanks. Looks like a great forum
Old Jun 7, 2010 | 01:46 PM
.032 should be good
Old Jun 7, 2010 | 01:58 PM
1966sportfury's Avatar
A.K.A Bob Dodge
the autolite plug you are looking for is (65) and the gap is 035. if its a "built" engine then i would use a cooler plug like (64) with the same gap. i my self use only autolite in everything i own,
Old Jun 9, 2010 | 08:09 PM
scotts74birds's Avatar
I go with stock specs for gap, unless i have an ignition system that recommends other. Champions all the way!
Panhead65
Mar 8, 2011 07:36 AM
69POLARA383
Sep 24, 2010 10:36 AM
Nomadci
Jul 10, 2010 06:18 PM
May 17, 2010 08:32 PM
will d
Feb 13, 2010 06:33 AM
