D100 400 tuck motor build
Old Jun 29, 2009 | 09:37 PM
I installed, well more like tried to install, a summit racing exhaust on my 78 D200. Never again. I would rather have installed the headers and have a professional exhaust shop do the rest.
Since your manifolds are leaking, I'd do the exhaust first. You have a good running motor, the 1 3/4" tubes will be good for it, and 2 1/2" pipes will be great for low to mid power which will match up with the Performer intake nicely. The 670 is just fine for that 400 also.
Old Jun 29, 2009 | 09:39 PM
I'd hold off on the cam for the time being. At least til you are ready to pull the motor and freshen it up. At that time, I'd look for a good tow/RV cam for it since you will be using it as a truck.
Old Jun 29, 2009 | 10:18 PM
The kit was a PITA to install, some of the pipes did not fit right, but the quality was great. With how many kits there are out there and the price of having an exhaust shop do it, I wish I spent the extra $200 on having a local exhaust shop do the work for me. It would have saved me a lot of time and headaches.
2 1/4" pipes are good for small block motors that have little to no upgrades. Big block motors shouldn't run on anything less that 2 1/2" pipes in my opinion (minus from the factory). A lot of people install performance carbs, intakes, and air filters because they are easy to do in the driveway. With a good amount of air going in, you'll want it to have enough room to be able to be pushed out, otherwise, what's the point of the upgrade. I'd get the headers and then take the truck to an exhaust shop and have them make up/install a kit for you. They will make sure that everything is supported and fitting just right.
Old Jun 29, 2009 | 11:30 PM
If you can find a kit that is 2 1/2" or even 3" I'd go with that. I had issues with the kit that I had going up and over the rear axle and turning out all at the same time. Maybe it was just me though.
Old Jun 30, 2009 | 12:47 PM
With just a full exhaust kit? Towing will be a little easier as the motor is allowed to breathe better. You should feel a little something but nothing major. Once you add on the intake, carb and a good air intake, you should nothing better throttle response, more power throughout the RPM range, maybe less gas mileage but nothing bad. the positives definitely outweights the negatives.
Old Jul 2, 2009 | 11:17 AM
40-60 with just an intake? That must be some intake! lol
Old Jul 5, 2009 | 04:27 PM
Polaradude's Avatar
The 670 should be ok, sounds like maybe timing/advance/retard.
Old Jul 9, 2009 | 05:23 PM
that wouldn't cause backfires, but it will cause the engine to run hotter
you better get it re-cored
Old Jul 9, 2009 | 05:35 PM
It's been a while since of messed with the timing on a mopar motor, but I THINK you have to have the vacuum advance disconnected and plugged to adjust teh timeing properly. I could be wrong though. AMC motors are like that.
Old Jul 9, 2009 | 05:36 PM
theomahamoparguy's Avatar
some things to ponder:
Is your vacuum advance working correctly? {the vacuum needs to go to the "ported" outlet on the carb.}If you have it connected to a full vacuum sorce, then yes it will have a ton of advance at idle and it will be hard to tune. The smog year dizzy's used a bunch of vacum advance {like 15-20 degrees}
I think you may have a hard time getting that original dizzy to work good with your combo. The smog motor years {400's} used a very slow advance to deal with the smog equip. Then there's the vacu. advance which added a ton of advance to cope with the egr system etc.
If you can find a decent dizzy from a 66-70 383. that would probably work better.
To see if your vacuum adv. is working, use a handheld vacuum pump and see if it holds vacuum or connect the dizzy's vac. line to a full vac. sorce and see if the timing moves while the engine is running [use a timing light.]
These are only my ideas without seeing the actual truck. Please disregard if they dont apply. .........ENJOY!!!........
Old Jul 11, 2009 | 03:50 AM
  #25
Polaradude's Avatar
Right on
Old Jul 11, 2009 | 04:37 AM
  #26
nice
Old Jul 12, 2009 | 04:06 PM
  #27
great job
earl65
Sep 19, 2013 07:40 PM
crmzendrgone
Dec 20, 2011 09:38 AM
minitruckin
Sep 16, 2010 09:09 AM
Zach8200
Nov 9, 2009 07:10 PM
Iskone
Sep 30, 2009 02:05 PM
