dodge magnum motor questions
Old Feb 5, 2011 | 06:42 PM
64dodgedart's Avatar
Exclamation dodge magnum motor questions
hey there i got a question for ya all . i got a 1993 dodge 360 the cylinder heads are still the shaft mounted rockers. it has a cast crank and dished pistons. i checked the compression is about 8.5 to 1. so with a stock bottom end how much horsepower can this combo handle? i wanted to build this setup to about 425HP can this rotation assembly take this?
thanks all
Old Feb 6, 2011 | 04:17 AM
No turbo, super charger or nitrious and you should be all set. I might look into a forged crank though.
Old Feb 6, 2011 | 11:48 AM
MercuryDon's Avatar
If your gonna chang out the crank you might as well put a stoker kit in it.
Old Feb 6, 2011 | 04:37 PM
ok, thanks for the info.! i want to leave the bottom end stock. how far do you think i could spin the stock rotation assembly to. i wanted to get 5,500 to 6,000.
Old Feb 6, 2011 | 05:23 PM
I think (99% sure) I read they could operated up to 6,500 RPM stock.
FabioV8
94
Sep 23, 2014 12:57 PM
Kadassa
Jul 2, 2014 06:26 AM
SPICOLIE203
Dec 4, 2013 10:24 PM
johnboy
Feb 1, 2012 11:20 AM
DaveR123
Jun 26, 2009 09:28 AM
