Engine Id
Old Mar 15, 2011 | 06:48 AM
Lloyd's Avatar
Engine Id
Trying to id the engine in a 1969 Charger.The vin#XP29H9B199208 says it is a 383 on the decode site's I've used.I do not think it is.I can anwser questions about a gm but am very unfamiliar with Mopar #'s.The engine and auto trans are in the car.It is a 2barrel engine.
Old Mar 15, 2011 | 08:17 AM
There is a casting number(s) on the passenger side of the block. In there it will tell you what motor it is and build/casting date. If you want, you are more than welcome to post them up here and someone will break them down for you.
Old Mar 15, 2011 | 11:32 AM
MercuryDon's Avatar
Big Blocks have a machined surface on the block behind the water pump. On RBs 440-413-426-383 this is horizontle,In a LB 350-361-383-400 this will be angled about 45 degrees. This surface will be stamped. Early engines use a 2 digit code (41=413 42=426) later motors are stamped with engine size 383,383HP(440,440HP,440HP2)
Old Mar 15, 2011 | 04:20 PM
A poor picture: The low block pad is on the flat protrusion on the pass. side that mates to the water pump. The RB (long stroke, raised block, 413 and larger is a horizontal rectangular pad that is "built into" the strip where the valley pan bolts down:
In the photo below, the pad is visible directly above the top water pump bolt on the driver's side, and directly to the driver's side of the distributor clamp
ProEmaster
Jun 6, 2007 11:31 AM
