727 Problems?
Old Mar 21, 2011 | 07:27 AM
motoadam's Avatar
727 Problems?
I have a 74 barracuda with a 360/ 727 combo. the problem i have is when i put the car in drive or reverse the car wants to die. If i quickly shift in to drive or reverse and quick get on the gas i can keep it running. It seems like the car want to take off as soon as it is in gear. Could this be a bad torque converter? The car idles at 1000-1100 rpm and does have a manuel valve body in it. any help would be great!
Old Mar 21, 2011 | 10:57 AM
Archer's Avatar
m -
It's not the trans. Sounds like a vacuum leak or something with the idle mixture or even the timing. You didn't give a lot of info, we're just guessing. If the motor is really "built" you might need a higher stall converter to get it into it's power band.
Old Mar 22, 2011 | 09:12 AM
motoadam's Avatar
I did find a large vacuum leak and now it works much better, thanks for the help!
Old Mar 22, 2011 | 09:41 AM
Archer's Avatar
m -
Lucky guess,
xvodysseusvx
Jun 25, 2018 04:38 PM
Colorado_Fury
Mar 3, 2014 12:32 PM
440 aspen
13
Apr 12, 2013 02:43 PM
pipdog69
Mar 13, 2012 11:01 PM
RandyYJ
Mar 13, 2009 01:59 AM
