727 problems
Old Apr 10, 2013 | 06:16 PM
440 aspen's Avatar
Unhappy 727 problems
Ive got a 727 for my 440 and i have a few issues with it. it slips in reverse if i give it more than a little tap on the gas. It also slips in second and third when im in drive but not first. i can shift it into 2nd manually and it wont slip at all. Im thinking I need to do a complete rebuild but can anybody tell me if its just the bands or governor needing to be adjusted? ive checked the fluid level and it right where it should be. Any help would be greatly appreciated.
Old Apr 10, 2013 | 06:58 PM
My manual troubleshooting guide says low line pressure (worn pump), rear servo malfunction or worn (do pressure test), governor malfunction or governor sealing rings worn.
There are a few other possibilities but each one points to pressure losses due to wear. No quick fix here me thinks.
Old Apr 10, 2013 | 07:09 PM
Gorts 5th's Avatar
Smile
if it's high milage ...
as these trannies get old they suffer from worn parts what color is your fluid , did you just change it?
have you adjusted the bands ?
if its clean thats ok but i am very sure that the valve body is filled with friction material so that s blocking small bleeds and passages
also the rubber seals start to harden and they don't seal
and the valve's are worn
so get ready for a rebuild.
Old Apr 10, 2013 | 07:33 PM
Archer's Avatar
440 -
Sounds like you need a band job ...
if not a cleaning/rebuild.
You could try a flushing, but the odd are the bands will need to be adjusted if not replaced.
Old Apr 10, 2013 | 09:00 PM
Do you have the throttle pressure / kick down linkage hooked up ??
Old Apr 11, 2013 | 04:31 AM
Gorts 5th's Avatar
Smile
post some pics.
i would love to see how you got that 440 in there
Old Apr 11, 2013 | 08:05 AM
jacilynn_s's Avatar
probably pooped out the seal in the low reverse clutch pack. Its the most common problem. Check the oil and smell it if it stinks rebuild the transmission.
Old Apr 11, 2013 | 01:21 PM
440 aspen's Avatar
Thanks for the input guys. I do have the kickdown hooked upand last time I checked the fluid was starting to get dark. i was planning on rebuilding it anyway so im not too disapointed. i just changed the fluid less than 500 miles ago and I have not adjusted the bands.
Old Apr 11, 2013 | 02:06 PM
440 aspen's Avatar
Just put up a few pics
Old Apr 11, 2013 | 02:25 PM
Gorts 5th's Avatar
Thumbs up
DUDE I LOVE IT THATS AN AWESOME APPROACH!
what a stuff bet shes fast as hell what gear you got in her?
wait til my brother see's her...
Old Apr 11, 2013 | 06:59 PM
440 aspen's Avatar
Thanks a lot man! im guessin its 4.10 maybe? It tops out at around 100. Its the stock 8.25 because i havent gotten a 3rd member for the 8.75 I want to put in yet. she definitly gets up and hauls *** though! I just wish my tranny would work like it should. Then she would really scream!
Old Apr 12, 2013 | 04:57 AM
Gorts 5th's Avatar
Smile
rebuilding a trany is not that hard get a service manual snap ring pliers a pick few trays clean uncluttered work area bench top
http://www.transmissioncenter.net/highperflist.htm
you can get all you need here or check out your local trany part supplier
Old Apr 12, 2013 | 09:04 AM
jacilynn_s's Avatar
Why do people put up pictures of the block castin or serial numbers but not the stamping of the engine identification pad right in front of the intake?
Old Apr 12, 2013 | 02:43 PM
Why are you asking unrelated questions in another person's thread?
Try helping or start your own!
xvodysseusvx
Jun 25, 2018 04:38 PM
Colorado_Fury
Mar 3, 2014 12:32 PM
pipdog69
Mar 13, 2012 11:01 PM
motoadam
Mar 22, 2011 09:41 AM
RandyYJ
Mar 13, 2009 01:59 AM
