Frozen antifreeze, please help!!!!!
Old Mar 4, 2009 | 01:42 PM
Commando's Avatar
I assume that one of your freeze plugs popped, you'll need to look up, or around to confirm this.
Old Mar 4, 2009 | 02:06 PM
it is probably just a popped freeze plug on the block
it can be repaired, but the engine has to come out
Old Mar 4, 2009 | 05:26 PM
X3 on the freeze plug.
The antifreeze should never have froze. That means that there was too much water in the mixture.
Old Mar 4, 2009 | 05:54 PM
BuckNeccid's Avatar
That does sound like the center freeze plug, but make sure you check the block when you pull the motor. I've had 2 440's that froze, popped the center plug, and then had longitudinal cracks from the freeze plug holes. (Nope, not on me, I got them that way)
Old Mar 4, 2009 | 06:12 PM
Polaradude's Avatar
Frost plug for sure, no biggie man.
Speedracer44
Mar 17, 2012 07:09 PM
macevanscb
Mar 8, 2010 03:10 PM
jane1043
May 7, 2008 07:56 PM
440doba
May 2, 2008 10:18 AM
moparcanblue
May 23, 2007 12:41 PM
