Gas fouled spark plugs
Old Aug 27, 2009 | 08:40 AM
sounds like not the right ballast resistor, not enough juice to the coil, not enough juice out of the coil, not large enough wires to the plugs, or that the motor is not properly grounded.
Old Aug 28, 2009 | 05:56 PM
scotts74birds's Avatar
Are you using the right coil? From what I read you want a 1.4-1.8 ohm coil for a ballast system, and a .6-.8 ohm coil for aftermarket 12 volt ignition. I may be wrong, so check it out for yourself before you start changing parts. Good luck.
Old Aug 29, 2009 | 09:13 AM
how many miles are on the motor that you are fowling plugs?
how many miles are on the plugs?
Old Aug 29, 2009 | 08:37 PM
that would be my guess
Old Aug 31, 2009 | 08:03 PM
have you completely checked over the distributor?
Old Sep 1, 2009 | 08:26 AM
what do you have the gap set to in the distributor?
Old Sep 2, 2009 | 12:30 PM
is the piece that is leaking held in by two bolts, and silicone is injected into the bolts?
Old Sep 2, 2009 | 02:45 PM
mine also leaks, even after i just replaced it
can you please post some pics when you get it off, and post a pic of the new seal that you are gonna use
thank you
Old Sep 2, 2009 | 03:01 PM
"Mopars dont leak, they just mark their turf."
Old Sep 2, 2009 | 04:47 PM
crmzendrgone's Avatar
NICE!!! Thats a good one I'll have to remember that one.
austin
Sep 18, 2012 12:37 PM
deadkelly
Aug 26, 2011 02:06 PM
mexbungalows
Jun 15, 2010 02:06 PM
eby94
Feb 23, 2009 08:07 AM
Commando
Feb 4, 2009 09:22 PM
