HELP!!!!
Old Jul 15, 2009 | 03:06 AM
Polaradude's Avatar
2 four's on a 318, holy cow. I would say there's your first problem.
Old Jul 15, 2009 | 08:38 AM
you are probably getting too much fuel first of all
that'll cause ignition in the tailpipe
are for the backfiring, your timing is probably 180 off
the car needs to be running to check your timing
Old Jul 15, 2009 | 09:25 AM
The carbs are 500 CFM first off. Second, Tunnel Ram intakes are only designed to be run on the strip, not the street. Since you have water in the carbs, who knows where else you have water. You wires could be 180 out, the carbs may need a rebuild or at least an extensive cleaning. Have you checked for compression in all the cylinders?
Old Jul 15, 2009 | 09:43 AM
Mopar_71's Avatar
WOW!!
That is a lot of gas for a 318.
You can check your INITIAL timing by removing the number 1 spark plug, remove the coil wire at the coil and then turn the engine over to get the #1 piston at the top of the "compression" stroke. The way most people identify that with out having the valve cover removed is to put your finger on the hole and when it pops your finger off, you’re at the top of the stroke. I usually get a new unsharpened pencil, put it in the head and turn the crank by hand to get the peak. Look at your harmonic balancer and verify you are at top dead center on your timing cover scale.
Once you are reading top dead center, remove your distributor cap to make sure the rotor is at the number 1 cylinder. The engine can run 180 degrees out but, like crap. (I learned that the hard way.)
If your distributor cap is cracked, it could create a cross fire also.
(I leaned that the hardway too and only with an oscilloscope to find it.)
Your engine should be able to idle and run with the initial timing set.
Now for what everyone else thinks might be the problem and that is your fuel delivery.
Do you have a stock fuel pump or an electric?
A stock pump might not be letting enough gas to... what size is those carbs?
If you have an electric pump, does it have an inline pressure gauge?
My single Edelbrock 750 sccm needs at least 6 ½ PSI to run at wide open throttle.
If you are getting enough fuel pressure, other things that may cause a back fire is a vacuum leak. Make sure you don't have something disconnected from your intake manifold that goes no where.
For your carbs. Screw both idle mixture screws in. Don't crank it down but just enough to where they start to get snug. Back them out the same amount of turns. They say 5 is good but on my small block 360 magnum with 1 carb. They are backed out 3 1/2 turns each.
It's hard to figure out stuff when you’re not actually at the motor but, I hope this gave you some ideas.
Let us know what you found and
p.s. Don't let GMdude try to convince you to get a GM ignition system
Mopar_71
Old Jul 15, 2009 | 10:17 AM
72RDRNR's Avatar
Also might have bad gas if it sat for 8 months. Have you filled the tank yet? Might want to try and drain it if you haven't added more to it yet. Also add some fuel additive to help remove water and varnish etc...
Old Jul 15, 2009 | 06:10 PM
Originally Posted by Mopar_71
WOW!!
very true
Old Jul 15, 2009 | 10:33 PM
theomahamoparguy's Avatar
Being out in the rain is one thing if it had some good air clearners on it. If not the rain could cause all kind of problems going down through the carbs. {think valves rusting etc.}
Old Jul 16, 2009 | 03:30 AM
Polaradude's Avatar
Originally Posted by moparbri69
Yea, I think the tunnelram needs to go! But right now, no, no electric- its manual fuel pump. Iam going to try the INITIAL timing, thanks for the info 71-I have a bullshit wedding this weekend, prob. do it monday night. I had a 318dart before with (1) edelbrock 4barell and would INSTANTLY start in my garage in middle of winter, Iam thinking, get rid of that crazy rig on the top and buy a new manifold and carb. But yeah, the previous owner had problems and said the car was outside for 8 months,with a big hole in the hood! I changed the oil before I did anything! would a compression check tell me if theres water in the cylinders??? What would cause the rotor to be out 180?? Thank you very much for the info!!!
If the car ran after the rain, there will be no water in the cylinders. I am with ya on changing intake and carb set up. Is there any water on the dipstick after you ran it ? If the car hasn't run after the rain, pull the plugs and rotate the motor by hand and watch the holes. Keep us posted man, we'll help if we can.
Old Jul 16, 2009 | 10:24 AM
scotts74birds's Avatar
Pardon me if I'm overlooking something here, but I was reading Mopar Muscle this month, and there was a tech answer on page 90 of the sept issue regarding the use of 340/360 heads on a 318. It stated that the 340/360 heads had a larger combustion chamber that would drop the compression ratio to 7.5:1 on a 318. Once again, I'm no expert, but it sounds like the motor was poorly thought out when built by the previous owner. Feel free to correct me if I'm wrong.
Old Jul 16, 2009 | 10:24 PM
Mopar_71's Avatar
Hey Moparbri69,
I think you are right about no water getting in your engine.
You would see it in the oil that you had changed.
You mentioned you took the tops off the carbs in your original post.
That should be good enough for the concern of water in the carbs and engine.
I agree with 72DRNR about the gas.
If it's old. It's no good. If it's like the color of a Sam Adams, you will need to drain your tank and flush it with new gas. But, if it's like the color of a Molsen Golden, you should be ok. Belive it or not, the smell of it can make the difference too.
If you have ever smelled varnish, it's about the same smell. (bad)
If it was me and I knew the gas was in there for 8 months, I'd drain it and flush it with new gas and change the fuel filter(s). I have 2.
A compression check will tell you a lot about your piston rings and cylinder head valves.
I'm not sure about what numbers you should get but I think anything above 110 psi is OKAY.
67 GTX
Polaradude
scotts74birds
theomahamoparguy
what do you think about compression specs for a 318?
You all seem to be really cool and helpful. Lets get this duster back on the road
If your cam and crank are all lined up properly. No bent push rods and lifters are in good shape, it will should give you consistant numbers. + or - 20 psi
If you do a compression check, let us know the numbers. If you have a low number I'm pretty sure I can guide you on some tips to determine if it's you rings or valves.
Not sure about the cylinder head compatability like scotts74birds said but, here is a link that might interest everyone:
http://www.youtube.com/watch?v=o9WvrxGQNL4
GIVES ME GOOSE BUMPS!!!!
As far as the intake manifold change... that is the best thing you can do.
I think you can use one of your 2 carbs for your new intake.
I recommend an Edelbrock air gap performer intake. but, you can choose what you want....
Keep us informed moparbri69
Old Jul 18, 2009 | 11:37 AM
i agree, with compression, anything above 110 psi is ok for the 318
Old Jul 18, 2009 | 01:57 PM
Polaradude's Avatar
X2 on that, I am a big fan of the leakdown test also.
We'll get ya going.
Old Jul 18, 2009 | 09:42 PM
Mopar_71's Avatar
Just how do you determine if gas is burning fast or slow on a paper towel?
A paper towel will actually make the gasoline SEEM to burn slower and make a lot of smoke from the carbon composition of the paper. If you do actually light the paper towel with gasoline, to extinguish it, use a class B extinguisher.
Hmmm. We are mixing the gasoline with air through a carburetor not a paper towelrator
Gasoline is extremely flammable, even though it is only a 3 on the NFPA and depending on where the gas originated depends on how oxygenated (ethanol or MTBE) it will be.
Over time, the additives evaporate and what is left is the gummy oil state that it started from.
Regardless of all this factual crap I wrote, lighting the gas on a secondary source of ignition (paper, cotton cloth, fiberglass, buddy’s *** crack, wood..) will not determine the chemistry of the gasoline or burn rate.
Stick to the color and age of it. 8 months is probably old gas.
Change it.
LOL! This is fun.....
You got to let us know the outcome
Old Jul 19, 2009 | 02:06 PM
dingo's Avatar
Junior Member
x3
