HP and Torque question in a 440 build
Old 10-07-2009 | 11:27 AM
68 Sat's Avatar
Finishing my build next week and dropping it into a 68 Satellite. I know it is a dumb question but can anyone give me estimations on this? Thanks
440 bored .30 over 9.5/1 compression
Speed Pro Hypereutectic pistons
Eddy RPM Performer Alum. Heads (84CC)
Eddy Performer intake with Eddy carb 750cfm.
Comp cam Advertised Duration 270/270, Lift .470/.470
TTI Headers 1 7/8
Moroso Baffled oil pan
Old 10-07-2009 | 11:36 AM
MrOldart2U's Avatar
Well Im sure there are a few that has Desk-top Dyno or some other programs but Im sure they will need more specific specs than you have provided....(ie: Crane Cam (slightly larger than stock) ) Just an observation.....
Old 10-07-2009 | 11:44 AM
68 Sat's Avatar
thanks I modified the specs
Old 10-07-2009 | 04:10 PM
scotts74birds's Avatar
Go onto comp cams website and download their camquest program. Pretty cool and fun to play what if? Good luck.
Old 10-08-2009 | 02:35 PM
is the compression 10.5 with the heads, or is it 9.5 after you factor in thermal efficiency?
Old 10-11-2009 | 07:13 PM
68 Sat's Avatar
I was told 9.5 to 1 . Not sure what thermal efficiancy is?
Old 10-12-2009 | 08:56 AM
with aluminum heads, you lose about 1 compression (not literally) because the aluminum doesnt hold in the heat
so, your engine will put out power like it has 8.5 to 1
Robert Weaver
09-23-2014 09:23 PM
shone190
09-14-2014 05:34 PM
bsfor
03-04-2013 01:10 PM
smackhonda
05-26-2010 08:17 PM
68 gtx
10-16-2009 04:43 PM
