HP and Torque question in a 440 build
Old Oct 7, 2009 | 10:27 AM
68 Sat's Avatar
Finishing my build next week and dropping it into a 68 Satellite. I know it is a dumb question but can anyone give me estimations on this? Thanks
440 bored .30 over 9.5/1 compression
Speed Pro Hypereutectic pistons
Eddy RPM Performer Alum. Heads (84CC)
Eddy Performer intake with Eddy carb 750cfm.
Comp cam Advertised Duration 270/270, Lift .470/.470
TTI Headers 1 7/8
Moroso Baffled oil pan
Old Oct 7, 2009 | 10:36 AM
MrOldart2U's Avatar
Well Im sure there are a few that has Desk-top Dyno or some other programs but Im sure they will need more specific specs than you have provided....(ie: Crane Cam (slightly larger than stock) ) Just an observation.....
Old Oct 7, 2009 | 10:44 AM
68 Sat's Avatar
thanks I modified the specs
Old Oct 7, 2009 | 03:10 PM
scotts74birds's Avatar
Go onto comp cams website and download their camquest program. Pretty cool and fun to play what if? Good luck.
Old Oct 8, 2009 | 01:35 PM
is the compression 10.5 with the heads, or is it 9.5 after you factor in thermal efficiency?
Old Oct 11, 2009 | 06:13 PM
68 Sat's Avatar
I was told 9.5 to 1 . Not sure what thermal efficiancy is?
Old Oct 12, 2009 | 07:56 AM
with aluminum heads, you lose about 1 compression (not literally) because the aluminum doesnt hold in the heat
so, your engine will put out power like it has 8.5 to 1
Robert Weaver
Sep 23, 2014 08:23 PM
shone190
Sep 14, 2014 04:34 PM
bsfor
Mar 4, 2013 12:10 PM
smackhonda
May 26, 2010 07:17 PM
68 gtx
Oct 16, 2009 03:43 PM
