Intake Manifolds
Old Nov 20, 2009 | 05:41 PM
Intake Manifolds
Were there any differences in the stock four barrel intake manifolds from 67-69 for 440's?
Were some dual plane, single plane?
Old Nov 21, 2009 | 07:23 AM
theomahamoparguy's Avatar
pretty much all the same. All were dual plane.
Old Nov 21, 2009 | 07:47 AM
so, there were no differences between a 67 intake and a 69 intake?
I was just wondering because the heads were different in the years, so I thought the manifolds might change too.
Old Nov 21, 2009 | 11:15 AM
Polaradude's Avatar
All the same buddy from 67-69 for the 440 4bbl, Part#2806178
Old Nov 21, 2009 | 03:13 PM
k
thanks guys
Old Nov 21, 2009 | 04:39 PM
deadkelly's Avatar
off topic i know
some pics of my Holley street dominator b inlet manifold , porting not finished yet btw it used to be a spread bore now its a full bore dk special . I'm also running 2 3/4 of carb spacer with gaskets ported right out all so . oh my mate bought a 1050 dominator carb just to see how it goes on my 383 , but i will be running my Holley 750 DP unless the 1050 works well & it's a clean swap . as you can see the 2nd & 3rd photo show std runner height & now they've been blended to the gasket for maximum high rpm volume . even std these street dominator manifolds make more power then a eddy rpm air gap & were rated number 3 over all by the mopar muscle flow bench test . now i may loose a bit of bottom end torque but my 3000 stall , 3.9 rear & 10.7:1 compression should take care of that .
Attached Thumbnails Intake Manifolds-265-porting-photos-010.jpg   Intake Manifolds-265-porting-photos-001.jpg   Intake Manifolds-265-porting-photos-009.jpg   Intake Manifolds-265-porting-photos-011.jpg
Old Nov 22, 2009 | 04:09 PM
looks great man
Old Nov 22, 2009 | 06:04 PM
deadkelly's Avatar
a few more pic'
i ported my gaskets while porting my head & this is what it looks like against my inlet manifold ports I'll match them today . my manifold is now a Ollie street / strip dominator manifold .
Attached Thumbnails Intake Manifolds-inlet-manifold-ports-001.jpg   Intake Manifolds-inlet-manifold-ports-002.jpg   Intake Manifolds-inlet-manifold-ports-003.jpg
hemi61
Nov 21, 2010 05:03 PM
Boz
Feb 8, 2010 04:24 PM
Boz
Dec 1, 2008 01:45 PM
J Dog
Jun 26, 2008 07:10 AM
supercarmanifolds
Dec 5, 2007 09:24 PM
