Intermediate steering shaft 1975 W200
Old 12-21-2009 | 10:14 AM
DodgeW200's Avatar
Does anyone have experience attempting to fix the classic Dodge truck 1/4 turn of the steering wheel before you feel the wheels respond phenomenon? I see that Borgeson makes a very expensive replacement shaft that seems to be "the" fix. All of thier listings however are for 79 and newer, I have a 1975. I wonder where you can get the original parts, and is the price worth that appraoch versus Borgenson's shaft?
Thanks,
Ray
Old 12-21-2009 | 10:54 AM
I've repaired a few but they all had tilt wheels and the three bolts that hold it all together inside were all loose.
Are you sure that you need a new shaft and not just a rag joint or are you looking at replacing the shaft because you don't want the rag joint?
Old 12-21-2009 | 12:01 PM
MrOldart2U's Avatar
Thanks,
Ray
Is it slop in the actual steering wheel or in the steering gear box itself? It should have an allen head/lock-nut on steering box that gives some adjust ment if it is in the steering box, just loosen the lock-nut, and then tighten the allen bolt, it may take 1 turn or less depending on how much wear is in box. If its not in the box make sure the rag joint is ok (if it has one). Thats a fiber/rubber disc joining the column to the gear box, if it is broken or worn out it will cause slack in steering. Other than that if its not a tilt wheel as 78D200 suggested i dunno...
Old 12-21-2009 | 12:52 PM
DodgeW200's Avatar
It is non tilt. Rag joint and steering box are ok, the play comes from the slip joint at the other end. I can watch the shaft coming from the steering wheel move a quarter turn before the intermediate shaft responds in kind. I can not find replacement parts for this.
Old 12-22-2009 | 04:33 AM
You may want to give flaming river a call and do a search online to see who makes steering shafts. It may be something that you need to have made up due to teh fact that there are not a high demand for these in these vehicles.
Old 12-30-2009 | 04:38 AM
rr69half6bbl's Avatar
sounds like the shaft has some slop on the steering wheel end then , just replace the column in the cab w/ another unit, man they made a blue million 74-7 trks, .I d spend a few bucks and time trying a salvage yard unit first to see if that even affected the outcome befoe i spnt big money to try a fix.
cuda341
03-06-2014 04:12 PM
fluffoffal
10-10-2012 07:03 AM
lifted150
12-30-2011 05:52 PM
DodgeW200
09-07-2009 04:42 PM
DodgeW200
09-07-2009 01:34 PM
Quick Reply: Intermediate steering shaft 1975 W200
