lifter adjustment on 318 poly engine
Old 05-09-2009 | 04:22 PM
theomahamoparguy's Avatar
valve lash/66 poly engine
First get the engine to operating temp, then adjust.
The clearance for the intake valve is .013.
The clearance for the exaust valve is .021.
You could make a chalk mark on the damper for every 90 degrees of crank rotation using the 0 mark [on the compression stroke] as the first one of the four marks. Than adjust the valves starting with the first in the firing order. Rotate 90 degrees and adjust the next in the firing order and so on until all are adjusted.
The firing order for the Polysphere motor is the same as the newer 318's.
1-8-4-3-6-5-7-2
Old 05-09-2009 | 09:04 PM
no problem, hey I used to live in florida [Clearwater].
Old 02-02-2014 | 02:52 PM
157forj's Avatar
Valve lash
I know this thread is old but, I was looking for valve lash settings. I thought I would throw in my 2 cents. If the intake is off your poly motor you can actually see the cam clear as day, except one lobe on each end. I simply turned the motor over for each lobe until I could see the peak of the lobe was on the opposite side of the lifter. Pretty simple if the intake is off. Hope that is helpful.
Old 02-24-2014 | 08:05 PM
moe7404's Avatar
been years for me. but you can do it cold. just add .001-.002 to the exth valve. the intake should be fine at the regular setting. chrysler many years ago had a sticker that showed which valves to set when the cam is at a cretin spot. the max wedge racers know about it.
merkfalc
09-07-2016 09:28 AM
juven
03-13-2010 12:21 AM
will d
02-27-2010 06:29 PM
Erikthegoalie
02-09-2009 03:34 PM
62sportsweep
04-07-2008 03:38 PM
Quick Reply: lifter adjustment on 318 poly engine
