lifter adjustment on 318 poly engine
Old May 9, 2009 | 04:22 PM
theomahamoparguy's Avatar
valve lash/66 poly engine
First get the engine to operating temp, then adjust.
The clearance for the intake valve is .013.
The clearance for the exaust valve is .021.
You could make a chalk mark on the damper for every 90 degrees of crank rotation using the 0 mark [on the compression stroke] as the first one of the four marks. Than adjust the valves starting with the first in the firing order. Rotate 90 degrees and adjust the next in the firing order and so on until all are adjusted.
The firing order for the Polysphere motor is the same as the newer 318's.
1-8-4-3-6-5-7-2
Old May 9, 2009 | 09:04 PM
no problem, hey I used to live in florida [Clearwater].
Old Feb 2, 2014 | 02:52 PM
157forj's Avatar
Valve lash
I know this thread is old but, I was looking for valve lash settings. I thought I would throw in my 2 cents. If the intake is off your poly motor you can actually see the cam clear as day, except one lobe on each end. I simply turned the motor over for each lobe until I could see the peak of the lobe was on the opposite side of the lifter. Pretty simple if the intake is off. Hope that is helpful.
Old Feb 24, 2014 | 08:05 PM
moe7404's Avatar
been years for me. but you can do it cold. just add .001-.002 to the exth valve. the intake should be fine at the regular setting. chrysler many years ago had a sticker that showed which valves to set when the cam is at a cretin spot. the max wedge racers know about it.
merkfalc
Sep 7, 2016 09:28 AM
juven
Mar 13, 2010 12:21 AM
will d
Feb 27, 2010 06:29 PM
Erikthegoalie
Feb 9, 2009 03:34 PM
62sportsweep
Apr 7, 2008 03:38 PM
