Magnum oil pan for LA 360
Old 02-07-2010 | 11:14 AM
Stauff73's Avatar
I was wondering if anyone has swapped a magnum oil pan onto a LA 360, I have read, putting a LA 360 on the newer 5.2 and 5.9 magnums, you just have to use the pan gasket that goes with the pan. Has anyone attempted this.
Old 02-08-2010 | 04:23 AM
Not I. Why would you want to do that?
Old 02-08-2010 | 07:12 AM
volaredon's Avatar
Member
might depend on availability.
also; the discrepancy between 318 and 360 pans "went away" with the Magnum series of engine coming out; they are both the same (and the same as the older 360)
I am putting a 318 Mag into my Volare, and had to get a 360 LA "car" pan.
Old 02-08-2010 | 09:20 PM
Stauff73's Avatar
So i can use the one piece oil pan seal, That comes on the magnum engines.
Old 02-09-2010 | 10:20 AM
theomahamoparguy's Avatar
I think you can do that . I read the Frank Adkins book and I cant remember exactly but I seem to remember something about using the magnum gasket with some minor mods. I dont have the book handy right now. i do know the oil pan will fit right on.
Old 02-09-2010 | 07:35 PM
Stauff73's Avatar
I have heard you can swap them if you use the proper gasket, and a one piece rubber gasket would be worth it to me.
rizzo67fish (11-20-2013)
Old 02-25-2010 | 11:07 PM
Mopar_71's Avatar
It won't work. The magnum and LA blocks are not the same.
I learned this the hard way.
There are a bunch of other things that didn't directly swap when going from LA to magnum block in a 70's car....
But for SURE they are not interchangable.
Old 02-27-2010 | 05:40 PM
volaredon's Avatar
Member
then how did they put the "crate" motors into a car??? The newer versions are based on the Magnum. this is the 1st I have heard that it "won't" work.
maca
02-13-2013 06:16 AM
mar-tay
11-13-2012 07:01 PM
johnboy
02-01-2012 12:20 PM
MarkyMark12345
04-10-2009 07:43 PM
dzltd02
10-28-2008 09:25 AM
