Main bearing replacement
Old Mar 30, 2024 | 03:37 PM
fishy's Avatar
Hi,Is it possible to replace main bearing shells with the crank in the block?
Changing like for like sizes for reliability.
Old Mar 30, 2024 | 03:39 PM
fishy's Avatar
Engine is 62 slant 6 forged crank.
Old Mar 30, 2024 | 10:57 PM
Yes fist remove the pan and then you can remove all but the last cap , flywheel end, just losen it to the point where you can hang the cap a half inch off the block. The crank will hang on the timing chain in the front and the transmission in the rear. At this point you can start pushing the upper bearing out on the edge that doesn’t have a small tang in it, tha end will need to come out of the block first. I’ve had luck pushing the bearing out with the bottom bearing laid on the crank then rotating the crank. You install the new bearing the same way put it on the crank and then rolling it in with the crank.
Old Mar 31, 2024 | 06:24 PM
fishy's Avatar
Thanks for your advice,i should be able to handle that.
Jase88
Jan 4, 2014 08:42 AM
mr.225
Oct 2, 2013 02:23 PM
67hemidart
20
Jan 14, 2013 12:20 PM
Grant
May 25, 2011 12:17 AM
1966DartConvertible
Nov 25, 2010 09:57 PM
