mopar control box "black"?
Old Sep 4, 2011 | 08:10 AM
olibass1's Avatar
I've got a "black" ignition control box on my Mopar electronic ignition. I can't seem to find this color of box anywhere to i.d. the application level. I've seen orange & chrome boxes, each for different performance levels, but I can't seem to find a Black box. Anyone identifiy this ?
Old Sep 4, 2011 | 10:39 AM
Archer's Avatar
olibass -
If it look like this
It's the OEM / factory ECU and not the HP Orange or Silver box.
Old Sep 4, 2011 | 03:02 PM
olibass1's Avatar
Originally Posted by Archer
olibass -
Yes...but mine is silver instead of gold.....same animal?
Old Sep 4, 2011 | 03:06 PM
Archer's Avatar
olibassi -
If I had to guess, it's a new manufacture OEM - type replacement, or someone took a spray can to it
Old Sep 4, 2011 | 03:45 PM
Color does not matter, unless the "color" was by someone that built a "true" box, IE Mopar/ Mopar Performance, IE "orange box."
I've seen some pretty cheap IE Chineseo chrome/ black/ no name boxes
The BIG thing that DOES matter is whether they are so called 4 or 5 terminal ECU
A 4 terminal ECU can work with EITHER a 2 or 4 pin ballast resistor
A 5 terminal ECU MUST have a 4 terminal ballast resistor
Other than that, they pretty much all interchange as far as running the car, disregarding quality or performance
A 4 pin box MAY (probably?) has 5 pins. So how do you know? Use an ohmeter on the 5th terminal, turn the probes around and check both to the box case and the other terminals. If it shows a good open on all checks, it's a 4 terminal box
Here's a 4 pin wiring diagram, so the "5th pin" is the blank spot lower right
http://www.mymopar.com/downloads/Ign...ystem_4pin.jpg
Be aware that this layout is looking down at the top of the box. Some diagrams you may find are looking INTO the connector plug
Old Sep 5, 2011 | 04:50 AM
olibass1's Avatar
olibassi -
Definitely not spray bombed......did you see the attached pic on my last post? Not good at adding pics ....had to use the "attachment" button. Shuldn't there be some part #s on it for i.d.?
Old Sep 5, 2011 | 04:51 AM
olibass1's Avatar
Here's a 4 pin wiring diagram, so the "5th pin" is the black spot lower right
Thanks again 440!
dhetticher
Mar 12, 2011 09:21 PM
SMRE
Jan 12, 2011 01:42 PM
Nomadci
Sep 5, 2010 01:16 PM
mystarcollectorcar.com
Apr 16, 2010 03:42 AM
