Name that power Steering pump?
Old Aug 21, 2014 | 08:02 AM
labradorian70's Avatar
66 monaco Name that power Steering pump?
Hello
I have a 66 Monaco with 383 in it and it did not come with PS pump from the factory. PS pump was added to this car sometime down the road. I believe sometime in the 70's.
My PS pump is making some noise. like a rattle, like something is loose inside but the pumps works just fine. There is a little play in the shaft(In and out) but not sideways.
So anyways I want to either replace this pump or fix it. i'm not familiar with power steering pumps.
Before I do anything I need to identify perhaps what car this pump came out off or year this pump might be, I need some info to work with if I need to get parts or a kit for it. attached are some pics.
I believe the dodge Monaco did not have PS available until 1968. but not sure.
1. Please help me identify this pump. see pics
2. What is in a rebuild kit? seals, bearings?
3. Should I just take the pump and send away and get it rebuilt.
Thanks for any direction. please let me know if you need more info.
cheers
Glen
Attached Thumbnails Name that power Steering pump?-20140820_182401.jpg   Name that power Steering pump?-20140820_182414.jpg   Name that power Steering pump?-20140820_182433.jpg
Old Aug 21, 2014 | 09:39 AM
Originally Posted by labradorian70
Hello
cheers
Glen
so far what I can tell is that it looks like a Federal pump.
Old Aug 21, 2014 | 02:22 PM
Your rite on the type (Federal).... Looks to be about a 1967... 1967 Dodge Monacos with 383's I know had those pumps.... You can get the kits from Napa auto parts of just gat a Cardone Reman....
http://www.cardone.com/Products/Prod...lter+available
Old Aug 21, 2014 | 03:59 PM
moe7404's Avatar
i had a 300 L its pump was mounted different. but yours looks like the bracket and the rest are mounted right. but above all do NOT flush the pump under power with solvent, kerosene, or gasoline, ONLY use oil.
Old Aug 22, 2014 | 04:56 AM
thanks.
Old Aug 22, 2014 | 06:52 AM
that helps greatly. now I need to decide between getting a Reman or just rebuild it myself. Reman Cardone one you linked to above from Rock Auto is $85 shipped to my door here in Canada. Not to bad.
cheers
Old Aug 22, 2014 | 09:05 AM
cheers
If I buy a Reman pump there are the following brands that came up at ROCKAUTO.com, for one example.
Cardone
ACDELCO
LARES
ATSCO
What is the best one to go with for quality?
I also have the option of sending my pump to Rock auto(im sure other places too) to be rebuilt.
Cheers
Old Oct 11, 2014 | 05:10 PM
Rooty's Avatar
I would not replace the Federal with another of the same brand - Saginaw's are way
superior and sit nicely below the right head. Saginaw's are more consistent in out
put and have a larger pulley due to their flow curves. Once you buy the bracketts
( I got mine from 440 Source for $50 ) you can hang any Saginaw pump in there
and pick them up at the auto wreckers fo $25, The Federal just has too small
a reservoir, too small a power robbing pulley and aren't widely available. If you
do go Saginaw, keep your belt cause it fits right on. Another thing you will
notice with the Federal is that if the belt gets loose or stretches, it rubs on
the water pump pulley because the belt runs so close - not so with Sag's
66Newport
Apr 22, 2013 04:43 PM
cork1958
Sep 10, 2012 02:45 AM
1968polara383
Jan 8, 2012 07:45 AM
brucewon
Apr 11, 2010 08:49 AM
heminate
Aug 17, 2009 08:07 PM
