need help on my mopar
Old Mar 30, 2011 | 06:52 PM
79powerwagon's Avatar
hey yall i have a 1979 dodge powerwagon with a 318 w/ 360 heads and pop top pistons and other goodys like that i bought it as my first truck my buddys dad had the motor in a drag racing duster ran two passes and pulled it out and put it in the truck and i bought the truck for 200 bucks but here is the bad i need a radaiotr for it and a fuel pump i am in automotive at are local career center so i can do my own work i dont have much money can someone lead me to a web site i can pick up this stuff cheap or i am i better off trying to go to a junk yard and try to find the stuff
ps the reasons it need a fuel pump it is not pushing fuel to carb it will crank but u have to use starting fluid but i dont like using it
thank you guys
Old Mar 30, 2011 | 07:18 PM
Archer's Avatar
70 -
Check eBay for aluminum radiators.
If you disconnect the fuel line from the carb and crank it, does fuel squirt out and did you try putting a fuel pressure gauge on it?
Old Mar 30, 2011 | 07:23 PM
yes i did no fuel coming out of the fuel pump the fuel filter is bone dry and thanks about ebay
Old May 29, 2011 | 01:00 PM
vengence99's Avatar
Had this problem. Check your sending unit in the tank. Mine was blocked and worked fine after i cleaned it out.
Old May 29, 2011 | 03:23 PM
While checking the sending unit replace all the rubber lines.. One may be cracked and the pump is just sucking air
Rumblefish318
Jun 30, 2013 12:56 PM
David
Sep 5, 2012 11:51 AM
kdykes
May 13, 2012 04:28 AM
kdykes
May 1, 2012 06:34 PM
bchetrick
Aug 26, 2007 02:31 PM
