Normal vacuum readings Mopar 493 stroker
Old Sep 16, 2019 | 09:02 PM
Mopar493's Avatar
Hi! I have newely build 493 cui stroker engine with Mahle forged flat top pistons with file fit rings, Edelbrock e-street 84cc cylinder heads, Edelbrock rpm intake manifold, comp cam xe275hl camshaft duration 231/237@ 0.050"lift 110 lobeseparation and 106 centerline, Edelbrock 800 avs carburator, Msd pro billet distributor and Msd 6al. The cam break in go good and i have now about 300 miles on the engine and its running great. I just wonder what vacuum readings you should expecting with this setup? Im reading 14 hg/in at idle and that im think is good with this cam? When i do the quick throttle test, give throttle and relise quickly the needle drops fast to 5 hg/in and bounce up to 20 hg/in and falling back to steady 14 hg/in. When you reading about this vacuum test it should drop to under 5 hg/in and bounce up to atleast 25 hg/in and after falling back to steady 17 to 20 hg/in, but thats numbers for stock engins i belive? Other wise this test shows me poor piston rings witch i not belive i have, the engine runs great and not drinking any oil and have no signs of blow by so what should i think about the vacuum readings? Maybe rings arent broken in really yet? Greatful for every though!
Old Sep 17, 2019 | 05:54 AM
Archer's Avatar
493 -
You're fine.
Old Sep 17, 2019 | 07:08 AM
Mopar493's Avatar
Originally Posted by Archer
493 -
You're fine.
Ok that sounds great, thank you for your answer
Old Sep 17, 2019 | 09:18 AM
My 500 idles with half that.🙃
Old Sep 18, 2019 | 06:19 AM
What you read was for stock engines.... I agree with the group... Your good... And that is a good vacuum number for what you have.
Old Sep 18, 2019 | 06:57 AM
Mopar493's Avatar
Ok, that sounds great, thanks alot for your answer!!
Old Sep 18, 2019 | 07:02 AM
Mopar493's Avatar
Ok maybe you have alot bigger cam than me, i keep the cam down for a good streetable engine, it idles great and have alot of torque, maybe i could have go up a bit with cam but still happy with the engine, it runs great
Undertakerman
Feb 8, 2016 02:13 PM
Myraman
36
Nov 1, 2013 01:27 PM
Coronet 500
Oct 9, 2013 02:50 PM
Barfly
Jul 11, 2010 07:17 PM
joelevelis@comcast.net
Oct 18, 2009 07:15 AM
