Overheating 440. Heat Control Valve?
Old Feb 7, 2009 | 02:02 PM
Commando's Avatar
What mixture do you run with the antifreeze?
Old Feb 7, 2009 | 02:11 PM
i originally had a 195 thermostat in my car, and the engine never went about 215
try putting a 160 thermostat or a 180 thermostat
what is your antifreeze mixture?
Old Feb 7, 2009 | 06:24 PM
You could have an air bubble in the system somewhere.
Old Feb 7, 2009 | 07:49 PM
I would start by installing a fan shroud as they do work and are iportant to the cooling of the cooling system.
As for the hoses. I would just replace them as they are not that much.
I don't think that installing a 160 will cause it to run hot though as it will stay open causing it to take a while to warm up.
To ge the air out, you can get a vacuum sytem to suck out all the fluid and create a suction on the system so that it will fill up completely with fluid.
stilllearning6
Oct 1, 2014 08:04 PM
recondotexas
Apr 14, 2011 07:57 PM
jar84203
Jun 18, 2009 05:31 PM
Kevin71
Feb 11, 2009 07:51 AM
Mopar-4-life01
Jun 15, 2008 03:05 AM
