Part Needed
Part Needed
The GTX needs its bushings replaced in the leaf springs. Where the leaf springs connects to the body, the pivot bushing is worn out there. Chrysler made a special tool for this job. Does anyone have it or know where to get it?
I did my 64 with a home made tool using threaded rod, nuts and washers. I takes some figuring out that's a little too complex and wordy for me to put in print, but it's do-able. You will need air power and patience though. Give it some thought and it will come to you. You will need a big socket that will bear against the spring loop, but allow the bushing to start out
thanks
i thought of that
i'll probably go that route
One trick I discovered when trying to get the outer bushing sleeve out, like upper control arms and such, is to use an air hammer/chisel once you've burned the rubber out. Sure works good, I've even used it on the lower bushings.
